Overwrite aimeos_catalog-list flexform in v23
loeffe1
Post by loeffe1 » 02 Apr 2024, 13:48
I am trying to overwrite the flexform used for aimeos_catalog-list but my changes are overwritten by the aimeos core.
In v21 I was able to simply overwrite it in Configuration/TCA/Overrides/tt_content.php in my custom extension but in v23 these changes are overwritten with the config from aimeos-typo3/Configuration/TCA/Overrides/tt_content.php.
How can I modify the flexform in v23?
Re: Overwrite aimeos_catalog-list flexform in v23
Post by aimeos » 03 Apr 2024, 10:55
That seems to be more a question if TYPO3 allows overwriting that file in the correct order (based on ext_emconf.php dependencies).
loeffe1
Post by loeffe1 » 04 Apr 2024, 07:01
While ext_emconf.php is no longer used in composer based installations with TYPO3 v12, your reply did help me with figuring out the problem. Turns out I was only requiring aimeos/aimeos-core in my custom extensions composer.json. Adding aimeos/aimeos-typo3 fixed it.
