Template: You are here: Back
sieg01
Post by sieg01 » 07 Apr 2024, 09:40
Bug or Feature?
Clean Template
aimeos_dist 23.7.1
aimeos 23.10.6
Browsing a product and want to go back to product assortment overview.
In the header the visitor can read
"You are here: Back"
When clicking on "Back", nothing happens, as it is not a link.
Re: Template: You are here: Back
Post by aimeos » 08 Apr 2024, 09:20
It's a link but there may be an overlay of another element depending on your CSS:
https://github.com/aimeos/ai-client-htm ... hp#L68-L70
You can check that in the browser console.
sieg01
Post by sieg01 » 08 Apr 2024, 15:57
Thanks for guiding. :)
aimeos wrote: 08 Apr 2024, 09:20 It's a link but there may be an overlay of another element
Yes, there is an overlay!
aimeos wrote: 08 Apr 2024, 09:20depending on your CSS:
Aimeos EXT runs "out of the box" the way it was imported.
No file modified or own aimeos extension activated.
Im running TYPO3 12.4.13
Where does the overlay come from?
Post by aimeos » 11 Apr 2024, 07:26
It depends on the version of the Bootstrap extension and maybe things. The default theme uses margins for the header which may interfere with different versions of the Bootstrap CSS. Best option is to add a custom CSS statement that fixes that.
sieg01
Post by sieg01 » 17 Apr 2024, 05:32
aimeos wrote: 11 Apr 2024, 07:26 It depends on the version of the Bootstrap extension and maybe things.
Sorry for my late respond. I missed your comment.
I downgraded from Bootstrap 14.0.7 to 13.0.5 and it didn't change anything.
I may start with a new clean install to see if I messed something up without realizing it.
Because if I am the only one experiencing it, then it must be my install :lol:
Post by aimeos » 17 Apr 2024, 08:20
Not necessarily, it could be also a general problem.
sieg01
Post by sieg01 » 20 Jun 2024, 09:05
aimeos wrote: 17 Apr 2024, 08:20 Not necessarily, it could be also a general problem.
Looks like.
I deactivated "Aimeos Shop - Catalog Stage Area".
So the "You are here: Back"-link isn't displayed anymore.
