A few topics to discuss
Metalics
Post by Metalics » 11 Jun 2024, 23:57
Hello Aimeos,
I want to discuss a few topics we have discovered:
1- static_info_country and language columns in fe_users table is not matching. If you register via Aimeos, static_info_country column is created as 2 letter code like "TR". But it should use 3 letter code like "TUR" to match. Same for language column, Aimeos is using lower case like "tr", but it would be upper case like "TR" to match with Typo3 register. Please see the image below:
https://ibb.co/tBNXzxP
2- "Save basket" function is visible also for non-logged-in users with new Aimeos version. How is it possible to save a basket unless you don't have a customer id?
On the other hand ehen you save a basket it is not visible in your profile page. If you check database after saving a basket, you can see that it has weird basket id and basket name is empty. Please see the image below:
https://ibb.co/Q9sLk1N
3- Product links in basket not correct. Let's say you have a product with link "domain.com/product-detail/d/hplc-column-50192-u". In basket product link is having product name at the last part: "domain.com/product-detail/d/partisil-hplc-column-10-ods-c18-reversed-phase-usp-l1-end-capped-no-4-6-x-250-mm-10-0-m-85-a"
4- Showing/hiding the invoice and delivery address in profile page requires bootstrap.js file because of it is using data-bs-toggle=collapse tag. That is a big problem for users who don't use bootstrap package. Furthermore bootstrap.js file conflicts with some private project's content. Maybe you can consider to change show/hide behavior of these addresses similar to order history show/hide function.
Re: A few topics to discuss
Post by aimeos » 13 Jun 2024, 08:47
Metalics wrote: 11 Jun 2024, 23:57 1- static_info_country and language columns in fe_users table is not matching. If you register via Aimeos, static_info_country column is created as 2 letter code like "TR". But it should use 3 letter code like "TUR" to match. Same for language column, Aimeos is using lower case like "tr", but it would be upper case like "TR" to match with Typo3 register. Please see the image below:
This was a change suggested by another TYPO3 user who used another TYPO3 extension for registration where the field is filled with two letter ISO codes. Seems like it's a problem we need another solution for but first we have to revert back that change. Unfortunately, we can do that only in dev-master for the next 2024.07 release because this is highly breaking even if we provide a migration.
Metalics wrote: 11 Jun 2024, 23:57 2- "Save basket" function is visible also for non-logged-in users with new Aimeos version. How is it possible to save a basket unless you don't have a customer id?
The customer should be redirected to the login page in that case and this seem to be not working in your case.
Metalics wrote: 11 Jun 2024, 23:57 3- Product links in basket not correct. Let's say you have a product with link "domain.com/product-detail/d/hplc-column-50192-u". In basket product link is having product name at the last part: "domain.com/product-detail/d/partisil-hplc-column-10-ods-c18-reversed-phase-usp-l1-end-capped-no-4-6-x-250-mm-10-0-m-85-a"
Confirmed and this problems exists since several versions if the product name and the product URL are different. Updates for 2024.04 and 2023.10 will be available soon.
Metalics wrote: 11 Jun 2024, 23:57 4- Showing/hiding the invoice and delivery address in profile page requires bootstrap.js file because of it is using data-bs-toggle=collapse tag. That is a big problem for users who don't use bootstrap package. Furthermore bootstrap.js file conflicts with some private project's content. Maybe you can consider to change show/hide behavior of these addresses similar to order history show/hide function.
Does it work without Bootstrap at all because the frontend is using Bootstrap cols, containers, etc. everywhere?
Post by aimeos » 13 Jun 2024, 08:57
The change regarding fe_users.static_info_country has been there since beginning of 2021:
https://github.com/aimeos/ai-typo3/comm ... 25f2dec12b
Did you change the registration extension during upgrade?
Metalics
Post by Metalics » 08 Mar 2025, 12:28
aimeos wrote: 13 Jun 2024, 08:57 The change regarding fe_users.static_info_country has been there since beginning of 2021:
Sorry for the late reply, somehow I forgot about this topic.
No, we did not change the registration extension, we have been using the most downloaded extension "sr_feuser_register" since the beginning.
Related to this topic;
We have Typoscript records for states like:
plugin.tx_aimeos.settings.common.states {
TR {
Adana = Adana
Adiyaman = Adıyaman
DE {
No matter which country you select, the states of all countries appear on the list. Is there any way to show only states of the selected country?
On the other hand, maybe you can consider to use static_country_zones for states in Aimeos.
Metalics
Post by Metalics » 08 Mar 2025, 12:31
This problem still exists (Aimeos V24.10.4).
Post by aimeos » 11 Mar 2025, 17:09
Metalics wrote: 08 Mar 2025, 12:31
The problem is fixed in 2024.10 but not if you have overwritten the template and didn't update it. Add this line to your overwritten template:
https://github.com/aimeos/ai-client-htm ... il.php#L25
Post by aimeos » 11 Mar 2025, 17:20
Metalics wrote: 08 Mar 2025, 12:28 We have Typoscript records for states like:
TR {
Adana = Adana
Adiyaman = Adıyaman
DE {
The states are added as optgroups for a select element:
https://github.com/aimeos/ai-client-htm ... #L256-L268
Maybe the problem is in the JS code or HTML structure if you've overwritten the address partial:
https://github.com/aimeos/ai-client-htm ... js#L82-L96
Metalics wrote: 08 Mar 2025, 12:28 On the other hand, maybe you can consider to use static_country_zones for states in Aimeos.
That wouldn't help and we've removed the static_info_tables plugin dependency 4 years ago due to delayed updates for new TYPO3 versions. Futhermore, this wouldn't work for Laravel.
