Class '\Omnipay\Klarna\CheckoutGateway' not found
joakim
Post by joakim » 28 Apr 2016, 12:51
I downloaded Klarna driver from GitHub
Copied contents to typo3conf/ext/aimeos_pay/Resources/Libraries/omnipay/klarna
Added service in Aimeos: Screenshot
When checkout in webshop, I only get:
Using Aimeos webshop with Typo3
Re: Class '\Omnipay\Klarna\CheckoutGateway' not found
Post by aimeos » 29 Apr 2016, 08:22
You have to execute
COMPOSER=composer.aimeos.json composer update --no-dev
to make the new files known to composer
derJu
Post by derJu » 19 Dec 2016, 15:11
Hi Aimeos
Hab das selbe Problem obwohl ich den Composer durchgeführt habe.
Class '\Omnipay\Postfinance\Gateway' not found
Vielleicht hast du mir ein Tipp wie man das auf die schnelle lösen kann?
Wo ran kann das noch liegen?
LG - derJu
derJu
Post by derJu » 19 Dec 2016, 15:32
i run the composer in typo3conf/ext/aimeos_pay is that right?
derJu
Post by derJu » 19 Dec 2016, 16:50
i run the composer like this an it works
Post by aimeos » 20 Dec 2016, 22:30
If you use the latest aimeos_pay release, it's only
