Javascript Error with basket-mini.js
robert63
Post by robert63 » 09 Oct 2024, 11:01
Upgrading from Typo3 11.5.34 to 12.4.20.
Aimeos from 22.10.9 to 23.10.3
Aimeos_dist 22.10.1 to 23.7.1.
php is 8.3 on both
Linux is Ubuntu 20.04.6 LTS
Now I have a Javascript reference error in line 130 of basket-mini.js. Can't find variable: $
$(function() {
AimeosBasketMini.init();
The mini basket is not working due to this.
Best regards
Robert
robert63
Re: Javascript Error with basket-mini.js
Post by robert63 » 09 Oct 2024, 15:57
Adding
page {
includeJS {
cashDom = https://unpkg.com/cash-dom/dist/cash.min.js
cashDom.external = 1
into Setup solves the problem.
But why is this necessary?
Post by aimeos » 10 Oct 2024, 07:36
You should include the app.js of the theme which contains cash-dom and the Bootstrap JS:
https://github.com/aimeos/ai-client-htm ... ult/app.js
robert63
Post by robert63 » 11 Oct 2024, 15:56
I cannot find in the documentation and also have trouble to figure out how to include the app.js correctly. Maybe you can give a hint.
Post by aimeos » 11 Oct 2024, 17:10
Did you use the page tree to create the necessary pages?
https://github.com/aimeos/aimeos-typo3#page-setup
robert63
Post by robert63 » 11 Oct 2024, 17:17
Since I updated from an older version I didn't import a new web tree. I still have the one from 22.10.9.
What is the difference between these?
Post by aimeos » 14 Oct 2024, 14:55
The CSS/JS files have been spit into one file per plugin for best performance. You must remove and re-add the TypoScript from the Aimeos extension in the shop root page to update your TypoScript settings.
robert63
Post by robert63 » 15 Oct 2024, 14:39
Thanks. Found everything and now it is working as expected.
