basket issue
goransabo
basket issue
Post by goransabo » 10 Oct 2024, 18:39
Hello again, one more issue
I have installed:
- php 8.2.23
- Typo3 12.4.21
- Aimeos 2023.10.7
Each time when I tried to add product to basket, after adding product, system redirect me to the basket page. It's right, but after redirecting on basket page is info message "Basket is empty".
any idea what can be wrong?
Best regards
Goran
Re: basket issue
Post by aimeos » 14 Oct 2024, 15:14
Did you customize the catalog/detail template and removed a necessary parameter for adding the product to the basket?
goransabo
Re: basket issue
Post by goransabo » 16 Oct 2024, 10:24
this problem was present from the start, before I add my custom aimeos extension
Re: basket issue
Post by aimeos » 16 Oct 2024, 12:11
Are there any Javascript errors in the browser console?
goransabo
Re: basket issue
Post by goransabo » 16 Oct 2024, 12:46
No Issues
Re: basket issue
Post by aimeos » 16 Oct 2024, 13:05
Did you update from an older version of Aimeos or do you installed TYPO3 and Aimeos 23.10 from scratch?
goransabo
Re: basket issue
Post by goransabo » 16 Oct 2024, 13:08
fresh install
- php 8.2.23
- Typo3 12.4.21
- Aimeos 2023.10.7
Re: basket issue
Post by aimeos » 16 Oct 2024, 13:16
Do you use composer or download TYPO3 and installed it manually?
goransabo
Re: basket issue
Post by goransabo » 16 Oct 2024, 13:23
composer
Re: basket issue
Post by aimeos » 22 Oct 2024, 13:00
Did you import the 23.x page tree?
https://github.com/aimeos/aimeos-typo3#page-setup
