adding stocklevel by PHP controller to new product
claude27
Post by claude27 » 01 Nov 2024, 10:35
I've created a secured area where frontend users can add events (for which later places will be sold with aimeos). Now I want to synchronize it automatically with the Ameos shop, starting now with creating new aimeos product items by a controller. I managed it already partially (title, type and price are created), but now I'm struggling on how to create the stock. Creating the price is working, I tried the same principle for the stocklevel but this seems not to work. What am I making wrong?
       $config = Base::config((array) $this->settings);
        //   $context = \Aimeos\TYPO3\Utility\Helper::getContext();
        $context = \Aimeos\Aimeos\Base::context($config);
        $productManager = MShop::create($context, 'product');
        $product = $productManager->create();
        $product->setCode($event->getUid()); // Eindeutiger Produktcode
        $product->setLabel($event->getTitle()); // Produktname
        $product->setType('event'); // Produkttyp
        // Create price (is working)
        $priceManager = MShop::create($context, 'price');
        $price = $priceManager->create()->setValue($event->getKosten())->setCurrencyId('EUR');
        // Add price to product
        $product->addListItem( 'price', $productManager->createListItem(), $price );
        // Create stock
        $stockManager = MShop::create($context, 'stock');
        $stock = $stockManager->create()->setProductId($event->getUid())->setType( 'default' )->setStockLevel($event->getTeilnehmerzahl());
        $stockManager->save( $stock );
        // Produkt speichern
        $product->setModified();
        $productManager->save($product);
TYPO3: 12.4.22
Aimeos: 24.4.2
PHP: 8.3
Thank you!!!
Re: adding stocklevel by PHP controller to new product
Post by aimeos » 01 Nov 2024, 15:59
Saving stock needs the product ID, not your event ID and you need to save the product before saving the stock item.
claude27
Post by claude27 » 04 Nov 2024, 18:47
Thank you very much! That was the solution.
