Not allowed to access JQAdm "dashboard" client
derJu
Post by derJu » 07 Nov 2024, 17:45
typo3 12 and the latest aimeos version are used.
When I call aimeos in the backend of typo3 as not admin but as editor with all rights for the shop I get the following error:
in /var/www/html/vendor/aimeos/ai-admin-jqadm/src/Admin/JQAdm.php line 46
  $view = $context->view();
  $config = $context->config();
  if( $view->access( $config->get( 'admin/jqadm/resource/' . $path . '/groups', [] ) ) !== true ) {
   throw new \Aimeos\Admin\JQAdm\Exception( sprintf( 'Not allowed to access JQAdm "%1$s" client', $path ), 403 );
  if( empty( $name ) ) {
   $name = $config->get( 'admin/jqadm/' . $path . '/name', 'Standard' );
does anyone have an idea how I can solve the problem quickly?
derJu
Re: Not allowed to access JQAdm "dashboard" client
Post by derJu » 07 Nov 2024, 20:03
When i down grade to Aimeos 24.7.2 i don't have the right problems, there it works. So maybe this will be a bug in 24.10.1?
technoxprt
Post by technoxprt » 08 Nov 2024, 06:19
You might want to double-check the user group permissions in TYPO3 to make sure the editor role has full access rights specifically for JQAdm resources.
derJu
Post by derJu » 08 Nov 2024, 07:39
Yes, I have checked this several times.
Post by aimeos » 08 Nov 2024, 13:38
There had been a change for TYPO3 v13 due to deprecations:
https://github.com/aimeos/aimeos-typo3/ ... 87aae2c879
Can you check what's returned for non-admin backend users and why?
Post by aimeos » 08 Nov 2024, 13:46
The problem was here: https://github.com/aimeos/aimeos-typo3/ ... 4ecb73073c
The fix is available in dev-master and 2024.10.x-dev and will be part of the next 24.10.2 release.
