Remove Title/Canonical set by Aimeos
shopseo
Post by shopseo » 17 Nov 2024, 21:16
Hi!
Is it possible to remove the title/canonical set by Aimeos?
I´ve found the setting to user the ones set by TYPO3, but now i´ve got two title-tags and two canonicals.
Scenario: create a normal page and add some products.
Thanks!
Greets,
Chris
Re: Remove Title/Canonical set by Aimeos
Post by aimeos » 18 Nov 2024, 08:50
To disable meta tags in Aimeos, use this config setting (also available for catalog list and supplier pages):
client/html/catalog/detail/metatags = 0
To disable TYPO3 meta tags, go to the "Settings" panel in the TYPO3 backend and select the settings for the Aimeos extension. There's a checkbox where you can disable TPYO3 meta tags for Aimeos pages.
shopseo
Post by shopseo » 18 Nov 2024, 09:27
Thanks, thats worked :-)
