Add basket box on list page for every product...
Bollerx
Post by Bollerx » 19 May 2016, 12:41
is it possible to Add basket box-button on list page for every product?
Re: Add basket box on list page for every product...
Post by aimeos » 19 May 2016, 12:48
Yes, enable this configuration option: https://aimeos.org/docs/Configuration/C ... basket-add
Bollerx
Post by Bollerx » 19 May 2016, 13:00
plugin.tx_aimeos.settings.client.html.catalog.lists.basket-add = 1
i tried to put in the root template, but i cant see any changes!?
Post by aimeos » 19 May 2016, 13:47
Yes, that's correct for version 16.4.x. Which one do you use?
For 2.4.x it's https://aimeos.org/docs/Configuration/C ... basket-add
("list" vs. "lists", due to the PSR-4 changes)
Bollerx
Post by Bollerx » 19 May 2016, 14:21
yes i'm using Aimeos 2.4.x, i included this to the template but stil not working>
plugin.tx_aimeos.settings.client.html.catalog.list.basket-add = 1
Post by aimeos » 19 May 2016, 15:30
Did you cleared the caches?
Bollerx
Post by Bollerx » 20 May 2016, 06:37
yes, i cleared the cache, i even did executed the scheduler with aimeos tasks. I can't see any changes, i have also two different(ver 2.4.x and 16.x.x) installation i tried on both as you described but still not working.
Post by aimeos » 20 May 2016, 08:59
Sorry, my fault. It's not implemented in 2.4.x but only available in 16.4.x.
The configuration you've posted for 16.4 is correct:
After clearing the frontend cache is looks like this: http://typo76.test.aimeos.com/index.php?id=13
