Product-Import (CSV) should be able to import a specific file
heural
Post by heural » 18 Dec 2024, 10:49
Hi Aimeos-Team,
we experimented with multi sites/shops (version 2023) and found a possible issue for the product import (here csv, but it sould the same for xml)
The controller/jobs/product/import/csv/location is a path and all files in this path will be included for a import. So far..
but if 2 cronjobs runs at the same time for different shops, this is not practicable. Because the products are mixed or ends up in unexpected results.
In this case the param controller/jobs/product/import/csv/location should be a specific file instead a folder.
Or how can we secure to import the specific products to there specific shops?
Thank you!
Thanks a lot!
Re: Product-Import (CSV) should be able to import a specific file
Post by aimeos » 18 Dec 2024, 23:01
That's fixed in 2024.x where each site uses it's own folder. The changes are breaking, so they haven't been back-ported to 2023.10 LTS
