Error for Aimeos Scheduled Tasks
Hi to all,
It is impossible to run Aimeos scheduler tasks via Cron, the following error appears;
[ERROR] No request given. ConfigurationManager has not been initialized properly.
Exception in scheduler task #3 (Aimeos Shop advanced scheduler)
Class: Aimeos\Aimeos\Scheduler\Task\Email6
File: /....../typo3_src-13.4.5/typo3/sysext/extbase/Classes/Configuration/ConfigurationManager.php:89
Typo3 V 13.4.5
PHP V 8.2.27
MySQL 10.6.21-MariaDB
Typo3 V 13.4.5
PHP V 8.2.27
Re: Error for Aimeos Scheduled Tasks
Since when does it occur and which Aimeos version are you using?
We have Typo3 V12.4.27 and Typo3 V13.4.5 in same environment (both is using Aimeos 24.10.4).
Scheduler tasks via cron is working with V12 but not working with V13.
We can confirm the problem when the scheduler tasks are run by a cronjob. From the TYPO3 backend it works as expected.
There's a ticket for that in the but tracker:
https://forge.typo3.org/issues/105554
There's an extension named which may be a workaround for the problem:
https://github.com/undkonsorten/extbase ... on-manager
We've added a workaround in 2024.10.x-dev, which will be in the next minor release.
We applied the code for workaround, now this error appears:aimeos wrote: 13 Mar 2025, 11:48 We've added a workaround in 2024.10.x-dev, which will be in the next minor release.
Uncaught TYPO3 Exception Too few arguments to function TYPO3\CMS\Extbase\Configuration\BackendConfigurationManager::__construct(), 0 passed in /......../typo3_src-13.4.7/typo3/sysext/core/Classes/Utility/GeneralUtility.php on line 2836 and exactly 8 expected
thrown in file /...../typo3_src-13.4.7/typo3/sysext/extbase/Classes/Configuration/BackendConfigurationManager.php
in line 72
Sorry, the last change didn't make it into the PR. Now, it's correct.
Thank you, now it is working.
