Scheduler Task Problem
Metalics
Post by Metalics » 22 May 2025, 20:54
1- After updating to Aimeos V25.4.1, order related e-mails are constantly being sent to the receiver.
2- When importing products from CSV, every 1000 st line is ignored and is not being imported. For example, you have 3000 products in your CSV file. Then 1000., 2000., 3000. products are not being imported.
I think this problem is caused by the "...csv/max-size = 1000" setting. Because when we set this to "max-size = 10000000" for unlimited import at once, all lines are being imported without any problem (This is not a new bug).
Typo3 V = 13.4.12
Aimeos = V25.4.1
PHP = V8.3.20
MySQL 10.6.22-MariaDB
Re: Scheduler Task Problem
Post by aimeos » 27 May 2025, 08:36
Metalics wrote: 22 May 2025, 20:54 1- After updating to Aimeos V25.4.1, order related e-mails are constantly being sent to the receiver.
Do you have any error messages in the Log panel?
Metalics wrote: 22 May 2025, 20:54 2- When importing products from CSV, every 1000 st line is ignored and is not being imported. For example, you have 3000 products in your CSV file. Then 1000., 2000., 3000. products are not being imported.
We've found the problem and it will be fixed in the next minor release.
Thank you for your report :-)
Metalics
Post by Metalics » 28 May 2025, 16:46
aimeos wrote: 27 May 2025, 08:36
No, there is no error in the Log panel.
By the way, Backend is not working properly when using the browsers in Dark mode because of the following JS error:
Post by aimeos » 29 May 2025, 13:44
The JS error for dark mode is already fixed and will be part of the next release.
Can you check why the order e-mail are sent more than once? Is the record with "email-sent" as type and "5" (authorized) or "6" (received) as value isn't created and if yes, what happened here:
https://github.com/aimeos/ai-controller ... #L306-L307
Metalics
Post by Metalics » 10 Jun 2025, 23:22
I am afraid I did not understand your question. Where can I see "email-sent" and other values for the record?
Post by aimeos » 11 Jun 2025, 07:18
In the mshop_order_status table, there are records for each order. At least one of them has the type "email-sent" with the number that is equal to the payment status value and this is the marker for Aimeos that the email for e.g. the "authorized" payment status (value: "5") has been already sent.
Metalics
Post by Metalics » 01 Jul 2025, 13:51
We have tested with a demo order. There is not any "email-sent" record in the mshop_order_status table although expected e-mails have been sent.
Post by aimeos » 03 Jul 2025, 09:45
Sorry, it must be "email-payment" and a value of "5".
In our tests using latest TYPO3 13.4.x and latest the Aimeos version, the e-mails have been sent and an entry in the mshop_order_status table has been created - regardless of being executed in the backend or by a cronjob executing "./vendor/bin/typo3 scheduler:run":
| 21 | 1.     |       24 | email-payment  | 5     | 2025-07-03 09:37:53 | 2025-07-03 09:37:53 | scheduler |
Then, no more payment related e-mails for that payment status have been sent any more.
If you don't have any related error messages in the Log panel, can you please add some debug statements here to see what happens, esp. here:
- https://github.com/aimeos/ai-controller ... d.php#L569
- https://github.com/aimeos/ai-controller ... d.php#L302
Metalics
Post by Metalics » 11 Jul 2025, 13:45
You can see a completed order image attached whose payment status is "received" and delivery status is "delivered".
There is no record with value "5" as you see.
I mean mails with content "We have received your payment and will immediately process your order." are sent in every mail circle until delivery status is changed to "delivered".
https://ibb.co/FLxW0gq2
Post by aimeos » 12 Jul 2025, 09:36
But there's one with "email-payment" and status "6" (received), so these type of e-mails shouldn't be sent any more. Can you also post the corresponding record from the mshop_order table and the e-mail content, you are receiving?
