[SOLVED] 404 page not shown if catalog not exist
heural
Post by heural » 05 Sep 2025, 12:01
Hi Aimeos-Team,
if we call a catalog-URL that does not exist, instead of showing 404 page, the exception is thrown (catalog with id 123 does not exist)
For product (detail-page) the 404 page is shown.
catalog id 123 not exists:
/shop/123/category-not-exist : exception, should 404
/detail/123/category-not-exist/product-name: exception, should 404
/detail/1234/category-exist/product-name-not-exist: 404, its ok
The TYPO3 error handling is "Show content from pid".
The route enhancer block from siteconfig:
routeEnhancers:
  Aimeos:
    type: Extbase
    namespace: ai
    defaultController: 'Catalog::list'
    # only on aimeos pages
    limitToPages:
      - 1323
      - 1326
      - 1331
      - 1328
      - 1365
      - 2022
      - 2025
      - 1344
      - 1340
      - 1343
      - 1337
    routes:
        routePath: '/pin/{pin_action}/{pin_id}/{d_name}'
        _controller: 'Catalog::detail'
        routePath: '/history/{his_action}/{his_id}'
        _controller: 'Account::history'
        routePath: '/watch/{wat_action}/{wat_id}'
        _controller: 'Account::watch'
        routePath: '/watch/{wat_action}'
        routePath: '/fav/{fav_action}/{fav_id}'
        _controller: 'Account::favorite'
        routePath: '/fav/{fav_action}'
        routePath: '/b/{b_action}'
        _controller: 'Basket::index'
        routePath: '/co/{c_step}'
        _controller: 'Checkout::index'
        routePath: '/p/{d_name}/{d_prodid}/{d_pos}'
        routePath: '/lt/{l_type}'
        _controller: 'Catalog::list'
        routePath: '/lp/{l_page}'
        routePath: '/ls/{f_sort}/{l_page}'
        routePath: '/l/{f_sort}'
        routePath: '/{f_catid}/{f_name}'
        routePath: '/{f_catid}/{f_name}/{d_name}'
    requirements:
      pin_id: \d+
      his_id: \d+
      wat_id: \d+
      fav_id: \d+
      d_prodid: \d+
      d_pos: '\d*'
      l_page: \d+
      f_catid: \d+
      d_name: '[^/]+'
      f_name: '[^/]+'
      f_sort: '[A-Za-z0-9_-]*'
      l_type: '[A-Za-z0-9_-]+'
      b_action: '[A-Za-z0-9_-]*'
      c_step: '[A-Za-z0-9_-]*'
    defaults:
      b_action: ''
      c_step: ''
      f_name: c
      f_sort: ''
      d_pos: '
We have
- Multi-Site
- Aimeos 2024
- TYPO3 v12.4.36
And is it possible to can do the routing without the catalog id? The detail/product url works fine without the product id.
Thank you for your support!
Thanks a lot!
boettner
Re: 404 page not shown if catalog not exist
Post by boettner » 05 Sep 2025, 12:11
I am using a Middleware and a custom page not found Handler for such cases:
Middleware:
<?php
namespace Your\Ext\Middleware;
use Your\Ext\Error\PageNotFoundHandler;
use Psr\Http\Message\ResponseInterface;
use Psr\Http\Message\ServerRequestInterface;
use Psr\Http\Server\MiddlewareInterface;
use Psr\Http\Server\RequestHandlerInterface;
use Throwable;
use TYPO3\CMS\Core\Utility\GeneralUtility;
class NotFoundToErrorHandlerMiddleware implements MiddlewareInterface
     * @throws Throwable
    public function process(ServerRequestInterface $request, RequestHandlerInterface $handler): ResponseInterface
        try {
            $response = $handler->handle($request);
        } catch (Throwable $e) {
            // Convert application exceptions (e.g., Aimeos errors) into your custom 404 page
            try {
                /** @var PageNotFoundHandler $handlerService */
                $handlerService = GeneralUtility::makeInstance(PageNotFoundHandler::class);
                return $handlerService->handlePageError($request, 'Application threw exception: ' . $e->getMessage());
            } catch (Throwable) {
                // As a last resort, rethrow to keep default TYPO3 exception handling
                throw $e;
        // Probe header to verify middleware runs on successful requests too
        $response = $response->withHeader('X-NotFound-Middleware', 'on');
        // Turn plugin-level 404 errors into your custom 404 page
        if ($response->getStatusCode() === 404 && $this->isHtml($response)) {
            try {
                return $handlerService->handlePageError($request, 'Application returned 404');
                return $response;
        return $response;
    private function isHtml(ResponseInterface $response): bool
        $type = $response->getHeaderLine('Content-Type');
        return $type === '' || str_starts_with($type, 'text/html');
Middleware registration:
return [
    'frontend' => [
        'your/ext/notfound-to-error' => [
            'target' => NotFoundToErrorHandlerMiddleware::class,
            'after' => [
                'typo3/cms-frontend/tsfe',
            'before' => [
                'typo3/cms-frontend/content-length-headers',
                'typo3/cms-frontend/response-propagation',
Handler:
<?php
namespace Your\Ext\Error;
use LogicException;
use TYPO3\CMS\Core\Error\PageErrorHandler\PageErrorHandlerInterface;
use TYPO3\CMS\Core\Http\HtmlResponse;
use TYPO3\CMS\Core\Http\RedirectResponse;
use TYPO3\CMS\Core\Http\RequestFactory;
use TYPO3\CMS\Core\Http\Uri;
use TYPO3\CMS\Core\Site\Entity\Site;
use TYPO3\CMS\Core\Site\Entity\SiteLanguage;
class PageNotFoundHandler implements PageErrorHandlerInterface
     * @var int
    protected int $pageNotFoundUid = 1;
     * @var ServerRequestInterface
    protected ?ServerRequestInterface $request = null;
    public function handlePageError(
        string                 $message,
        array                  $reasons = []
        $this->request = $request;
        return new HtmlResponse($this->getPageNotFoundContent(), 404);
     * @return string
    protected function getPageNotFoundContent(): string
        $url = $this->getPageNotFoundUrl();
        $requestFactory = GeneralUtility::makeInstance(RequestFactory::class);
        /** @var ResponseInterface $response */
        $response = $requestFactory->request($url, 'GET');
        if (($response->getStatusCode() === 200) &&
            str_starts_with($response->getHeaderLine('Content-Type'), 'text/html')) {
            return $response->getBody()->getContents();
        throw new LogicException('Could not read content of ' . $url, 1594134183);
     * @return string
    protected function getPageNotFoundUrl(): string
        /** @var Site $site */
        $site = $this->request->getAttribute('site');
        /** @var Uri $uri */
        $uri = $site->getRouter()->generateUri($this->pageNotFoundUid, ['_language' => $this->getLanguageIdentifier()]);
        return $uri->__toString();
     * @return int
    protected function getLanguageIdentifier(): int
        /** @var SiteLanguage $language */
        $language = $this->request->getAttribute('language');
        return $language->getLanguageId();
Here are the docs for Middlewares and custom error handlers in case you don't know how to configure it:
https://docs.typo3.org/m/typo3/referenc ... wares.html
https://docs.typo3.org/m/typo3/referenc ... Index.html
heural
Post by heural » 08 Sep 2025, 09:24
Hi @boettner,
thank you very much for code! That helped me a lot...
Thanks a lot!
Re: [SOLVED] 404 page not shown if catalog not exist
Post by aimeos » 02 Oct 2025, 12:28
Starting from 2025.10 LTS, Aimeos will return 404 errors if the category in catalog/lists and the supplier in supplier/detail isn't found.
In addition, resolving categories by f_name and suppliers by s_name only will be possible like for products with d_name.
