Catalog XML import not working
loeffe1
Post by loeffe1 » 07 Nov 2025, 10:38
After upgrading from v22 to v25, my scheduler tasks are no longer working.
The tasks are being executed without any errors, but nothing is imported and no backup file is being generated. I tried using the xml provided here https://aimeos.org/docs/latest/cronjobs ... ml-import/ but to no avail.
This is my TypoScript:
plugin {
    tx_aimeos {
        settings {
            controller {
                jobs {
                    catalog {
                        import {
                            xml {
                                location = /var/www/html/public/fileadmin/user_upload/XML/catalog.xml
                                backup = /var/www/html/public/fileadmin/user_upload/XML/backup/catalog_%Y-%m-%d-%H:%i:%s.xml
I am on TYPO3 13.4.19 running on ddev.
Re: Catalog XML import not working
Post by aimeos » 07 Nov 2025, 10:44
The "backup" and "location" configuration has been changed to paths relative to the virtual file system defined here:
https://github.com/aimeos/aimeos-typo3/ ... hp#L74-L78
That way, there's no problem with different paths between staging/production and it can be also a cloud storage to retrive the files from.
loeffe1
Post by loeffe1 » 24 Nov 2025, 15:48
aimeos wrote: 07 Nov 2025, 10:44 The "backup" and "location" configuration has been changed to paths relative to the virtual file system defined here:
Thank you!
