Extending managers
nvindice
Extending managers
Post by nvindice » 09 Dec 2025, 08:47
Hi Aimeos team,
I extended the stock manager a long time ago by adding a new field to the database, "status". Now I'm trying to adapt my custom solution to "the easy way" following this tutorial: https://aimeos.org/docs/2025.x/models/extend-managers/
However, when I use the following code in my decorator:
private $attr = [
	'stock.status'=> [
		'internalcode' => 'status',
		'label'=>'Product Stock Status',
		'type'=> 'string',
...the status property is not available. I need to remove the "stock." prefix to make it work. However, it is then named without the prefix. What am I doing wrong?
Re: Extending managers
Post by aimeos » 11 Dec 2025, 09:25
Can you post your complete decorator, please?
nvindice
Post by nvindice » 11 Dec 2025, 09:42
Yes, of course:
<?php
namespace Aimeos\MShop\Stock\Manager\Decorator;
 * @package MShop
 * @subpackage Stock
class Status extends \Aimeos\MShop\Common\Manager\Decorator\Base
	private $attr = [
		'stock.status'=> [
			'type'=> 'string', // integer, float, etc.
    public function getSaveAttributes() : array
        return parent::getSaveAttributes() + $this->createAttributes( $this->attr );
    public function getSearchAttributes( bool $sub = true ) : array
        return parent::getSearchAttributes( $sub ) + $this->createAttributes( $this->attr );
I use the property in templates/admin/jqadm/product/item-stock.php:
                        <td class="stock-status optional">
                            <select class="form-control custom-select item-typeid" tabindex="<?= $this->get( 'tabindex' ); ?>"
                                v-bind:name="`<?= $enc->js( $this->formparam( ['stock', '_idx_', 'stock.status'] ) ) ?>`.replace( '_idx_', idx )"
                                placeholder="<?= $enc->attr( $this->translate( 'admin', 'Availability  status (optional)' ) ) ?>"
                                v-bind:readonly="!can('change', idx)"
                                v-model="item['stock.status']" >
                                <option value=""></option>
                                <option value="low" v-bind:selected="item['stock.status'] == 'low'">Niedriger Bestand</option>
                                <option value="remainder" v-bind:selected="item['stock.status'] == 'remainder'">Restbestand Kollektionsende</option>
                                <option value="delay" v-bind:selected="item['stock.status'] == 'delay'">Verzögerte Lieferung</option>
                                <option value="uncertain" v-bind:selected="item['stock.status'] == 'uncertain'">Evtl. nicht lieferbar</option>
                            </select>
                        </td>
(EDIT: Fixed a small mistake)
nvindice
Post by nvindice » 11 Dec 2025, 11:37
In Common\Item\Base function toArray() line 433, only values with a key not containing a '.' are injected into the array.
https://github.com/aimeos/aimeos-core/b ... #L431-L436
Am I right that this prevents the decorator from working the expected way?
Post by aimeos » 11 Dec 2025, 11:54
At least the strpos() in fromArray() and toArray() prevents the data from being added and returned by that methods.
This change may fix the issue without returning the hidden data like ".catalog":
if( strpos( $key, '.' ) === false ) {
// to
if( !strpos( $key, '.' ) ) {
Then, FALSE and 0 will skip, dots in the middle will pass.
What do you think?
nvindice
Post by nvindice » 11 Dec 2025, 12:30
Sounds like a good solution to me!
Post by aimeos » 15 Dec 2025, 12:23
Done in dev-master and 2025.10.x-dev
nvindice
Post by nvindice » 11 Mar 2026, 15:13
Hi Aimeos team,
the change got reverted last week - may I ask, why?
Is there any other solution to make a decorator work the expected way?
Thank you.
Nils
Post by aimeos » 12 Mar 2026, 09:20
The change caused several issues incl. one security issue where data is exposed that is kept private before.
We are very sorry but due to those problems, using custom search key names including dots can not be supported. Please use "status" or "stock_status" instead.
nvindice
Post by nvindice » 13 Mar 2026, 08:11
Thank you for the explanation. The documentation should be changed then, because it says:
The value for internalcode must be SQL alias of the table, a dot and the column name enclosed in quotation marks (here: 'mpro."mycolumn"')
It took me a couple of hours to find the problem in the first place.
