Hard limit 500 when loading attribute values (solved)
pla
Post by pla » 26 Feb 2026, 07:41
i have a problem getting all attributes of my imported products to be loaded in the frontend. The problem is, that only some attributes are shown in the filter list. I have searched in the code and found that in the controller src/Client/Html/Catalog/Filter/Atribute/Standard.php the filter values get loaded:
$attributes = \Aimeos\Controller\Frontend::create( $this->context(), 'attribute' )
	->uses( $domains )->type( $attrTypes )->compare( '!=', 'attribute.type', ['date', 'price', 'text'] )
	->sort( '-position' )->slice( 0, 10000 )->search();
And even though there is a slice of 10.000 here I only get 500 items which looks to me that there must be a limit set. Because when I change the sort to e.g. '-position' to turn the ordering around I get also 500 but different values and therefore different attributes to be displayed in the filter list.
I have now searched in all config folders of all aimeos packages to see if there is a LIMIT of 500 in the predefined SQL statements but found nothing. Does someone else ever had this problem and fixed it?
I hope someone can help here. Thanks and kind regards
Patrik
pla
Re: Hard limit 500 when loading attribute values
Post by pla » 26 Feb 2026, 09:21
I have now found the solution to this problem by myself.
There is a configuration for that which was (at least for me) hard to find.
The limit can be changed with this setting:
tx_aimeos.settings.controller.frontend.common.max-size = 1000
Hope this helps someone else
