Taxflag from TypoScript not respected
promptnet
Post by promptnet » 23 Mar 2026, 16:54
I have set
plugin.tx_aimeos.settings.mshop.price.taxflag = 0
in the TypoScript Setup, and the rest of the TypoScript in that file is working, and in the TYPO3 backend it shows that the value is set correctly.
But, unfortunately, the value is not respected. The basket and the checkout show the prices with tax included.
And, when I set
$priceTaxflag = 0
instead of
$priceTaxflag = $price->getTaxFlag();
then the prices are shown with tax excluded.
What can I do to have the tax excluded (correctly)?
TYPO3: 12.4.43
Aimeos: 24.10.5
PHP: 8.2
Re: Taxflag from TypoScript not respected
Post by aimeos » 24 Mar 2026, 08:52
For the frontend, the setting is correct but it's better to add this setting to a PHP config file so it's available in the scheduler tasks too.
promptnet
Post by promptnet » 25 Mar 2026, 07:49
Thank you very much! That works perfectly.
