product price and buying button missing in detail-page
mr_typo3worker
Post by mr_typo3worker » 15 Apr 2026, 07:42
I'm new to Aimeos and setting up a new composer instance on a TYPO3 13.* system.
I managed tot get as far as, having categories, and a product. The new product is visible on the catalogue and on the detail-page. Only thing is, there is no price shown and no button or any other parts to select and buy the product?
What Am I missing so far?
I'm using the bootstrap package, site is in English, currency Eu. Any help on this?
Re: product price and buying button missing in detail-page
Post by aimeos » 15 Apr 2026, 08:55
Did you add a price to the products and checked if the used currency matches the language/currency combination in the Locale > Locale panel?
mr_typo3worker
Post by mr_typo3worker » 15 Apr 2026, 09:12
I was just going post a reply that I found out that it has to do with the languages settings. So now the product and price is available and can be ordered. Now I have to find out how further shape the process. Nice :)
- How can I get a price (and button) in the list view as well?
- Any samples of "dutch" shops and how to apply shipping options (post nl, dpd, dhl or others) and payment options (paypall, ideal).
- How to print labels and other docs for shipping (brother labelprinter) is there a plugin or other easy way to get that.
Post by aimeos » 18 Apr 2026, 17:42
mr_typo3worker wrote: 15 Apr 2026, 09:12 - How can I get a price (and button) in the list view as well?
There's a configuration option to enable that:
https://aimeos.org/docs/2024.x/config/c ... basket-add
mr_typo3worker wrote: 15 Apr 2026, 09:12 - Any samples of "dutch" shops and how to apply shipping options (post nl, dpd, dhl or others) and payment options (paypall, ideal).
In the showcases page are Dutch shops too:
https://aimeos.org/showcases
mr_typo3worker wrote: 15 Apr 2026, 09:12 - How to print labels and other docs for shipping (brother labelprinter) is there a plugin or other easy way to get that.
Label printing isn't supported out of the box in Aimeos and you have to implement that yourself depending on the delivery provider you are using.
mr_typo3worker
Post by mr_typo3worker » 29 Apr 2026, 10:11
Wanted to work on the aimeos Typo3 shop again (after first removing it). Now ending uo with an sql error which I can not solve. Seems to be an issue with site id I guess? So that part is not clear to me. What should the site id be? I left it at default in the extension/ config. Or is there an other reason for this error? Tried by composer remove and install again. But no difference. Had it working before in the same TYPO3 instance. :)
 (1/1) Aimeos\Base\DB\Exception
SQLSTATE[42S02]: Base table or view not found: 1146 Table 'my_db_2026_2013.mshop_locale_site' doesn't exist: SELECT mlocsi."id" AS "locale.site.id", mlocsi."siteid" AS "locale.site.siteid", mlocsi."parentid" AS "locale.site.parentid", mlocsi."label" AS "locale.site.label", mlocsi."code" AS "locale.site.code", mlocsi."status" AS "locale.site.status", mlocsi."icon" AS "locale.site.icon", mlocsi."logo" AS "locale.site.logo", mlocsi."rating" AS "locale.site.rating", mlocsi."ratings" AS "locale.site.ratings", mlocsi."refid" AS "locale.site.refid", mlocsi."theme" AS "locale.site.theme", mlocsi."config" AS "locale.site.config", mlocsi."level" AS "locale.site.level", mlocsi."ctime" AS "locale.site.ctime", mlocsi."mtime" AS "locale.site.mtime", mlocsi."editor" AS "locale.site.editor" FROM "mshop_locale_site" mlocsi WHERE ( mlocsi."code" = 'default' ) GROUP BY mlocsi."id", mlocsi."siteid", mlocsi."parentid", mlocsi."label", mlocsi."code", mlocsi."status", mlocsi."icon", mlocsi."logo", mlocsi."rating", mlocsi."ratings", mlocsi."refid", mlocsi."theme", mlocsi."config", mlocsi."level", mlocsi."ctime", mlocsi."mtime", mlocsi."editor" ORDER BY mlocsi."id" ASC LIMIT 1 OFFSET 0
Post by aimeos » 29 Apr 2026, 17:28
Seems like your database doens't contain any Aimeos tables any more. Run from command line:
./vendor/bin/typo3 aimeos:setup
