Non-recoverable-error after update
franzrudolf
Post by franzrudolf » 28 Jul 2016, 17:47
after I updated my system from version 2.4.6 to 16.7.0 (TYPO3-Dist) I got an "non-recoverable error". In the admin-interface this is shown (which I don't understand):
Fehler Executing statement " SELECT mordba."id" AS "order.base.id", mordba."siteid" AS "order.base.siteid", mordba."sitecode" AS "order.base.sitecode", mordba."customerid" AS "order.base.customerid", mordba."langid" AS "order.base.languageid", mordba."currencyid" AS "order.base.currencyid", mordba."price" AS "order.base.price", mordba."costs" AS "order.base.costs", mordba."rebate" AS "order.base.rebate", mordba."tax" AS "order.base.taxvalue", mordba."taxflag" AS "order.base.taxflag", mordba."comment" AS "order.base.comment", mordba."status" AS "order.base.status", mordba."mtime" AS "order.base.mtime", mordba."editor" AS "order.base.editor", mordba."ctime" AS "order.base.ctime" FROM "mshop_order_base" AS mordba WHERE ( mordba."siteid" IN (1) AND mordba."id" = 50 ) GROUP BY mordba."id", mordba."siteid", mordba."sitecode", mordba."customerid", mordba."langid", mordba."currencyid", mordba."price", mordba."costs", mordba."rebate", mordba."tax", mordba."taxflag", mordba."comment", mordba."status", mordba."mtime", mordba."editor", mordba."ctime" LIMIT 100 OFFSET 0 " failed: SQLSTATE[42S22]: Column not found: 1054 Unknown column 'mordba.tax' in 'field list'
Can anybody help, please?
Re: Non-recoverable-error after update
Post by aimeos » 28 Jul 2016, 17:48
You haven't executed the update script of the extension. When you update in the extension manager directly from TER, this should happen automatically.
