Wrong E-Mail-language after update from 2.4.6 to 16.7.0
franzrudolf
Post by franzrudolf » 31 Jul 2016, 12:39
Hi, it's me one more time... :-)
Since I updated Aimeos (Typo3-Ext) from 2.4.6 to 16.7.0 I use the "scheduler for aimeos-shop-emails" instead of the "Extbase-CommandController-Task (extbase)" (and the respective mail-jobs) which obviously doesn't exist any longer.
But now all E-Mails are sent in English instead of German as they were before.
Can you give a hint what's wrong , please...?
Thank you in advance
Ralph
Re: Wrong E-Mail-language after update from 2.4.6 to 16.7.0
Post by aimeos » 01 Aug 2016, 14:43
Can you have a look into the addresses of your orders (mshop_order_base_address table)? What's the language stored there?
franzrudolf
Post by franzrudolf » 01 Aug 2016, 17:14
The langid in the mshop_order_base_address-table is always NULL (in all orders AFTER the update. In all previous orders, that worked fine, it's de)
Post by aimeos » 02 Aug 2016, 10:10
The language should be set in the address part of the checkout process. Did you removed the language selection there? If yes, you should add it using the configuration for "hidden" form elements again:
https://aimeos.org/docs/Configuration/C ... ing/hidden
franzrudolf
Post by franzrudolf » 02 Aug 2016, 12:35
Okay, thank you. I fixed it now by adding these two commands (only the "hidden"-command didn't work):
plugin.tx_aimeos.settings.client.html.checkout.standard.address.delivery.mandatory {
8 = order.base.address.languageid
plugin.tx_aimeos.settings.client.html.checkout.standard.address.delivery.hidden {
Post by aimeos » 03 Aug 2016, 07:20
franzrudolf wrote: plugin.tx_aimeos.settings.client.html.checkout.standard.address.delivery.mandatory {
That's too much. Either "mandatory" if it should be shown or "hidden" if you only have one value and it should be not shown. Use this in you case only:
franzrudolf
Post by franzrudolf » 03 Aug 2016, 09:33
I tried this, but without the mandatory-command the e-mails switched to english again. To me this is strange, too, because, if I only set the mandatory-command, German language is set by default (if you want to switch to English you must choose this manually).
Post by aimeos » 05 Aug 2016, 14:00
Ah, ok. Mandatory is to enforce value and hidden is to don't show the select drop-down.
By default, the config.language setting of your TYPO3 page tree is used if there's also a locale entry available in the expert mode admin interface (Locale tab) for the site and language.
