Order Mails - Immediately upon confirmation? And batch size?
andreas.allacher
I would like to know:
Is it possible to instead of using the scheduler - or in addition to the scheduler - is it possible to also let order mails be sent immediately when the user gets to the confirmation page?
Also:
Is it possible to configure how many e-mails the scheduler should send per execution? Or maybe just a timeout after a certain number.
This most likely will not be a problem as the scheduler should be set to execute the mail sending quite often but if one waits too long it is possible that the server itself will deny the mail sending (because too many are sent at once).
Also:
