Invalid locale ""
27bit.ru
Invalid locale ""
Post by 27bit.ru » 01 Mar 2017, 13:45
I tried to solve the problem with the date( Re: Dates in account history ) of the letter to a buyer, I have replaced the file "ru" and "ro.po" to "aimeos/resourses/private/extensions/ai-client-html/client/i18n"
Then I had a mistake when entering the expert mode.
Invalid locale ""
And in the journal
Core: Exception handler (WEB): Uncaught TYPO3 Exception: Invalid locale "" | Aimeos\MW\Translation\Exception thrown in file /home/virtwww/w_new-texnodo_38e99323/http/typo3conf/ext/aimeos/Resources/Libraries/aimeos/aimeos-core/lib/mwlib/src/MW/Translation/Base.php in line 34. Requested URL: http://new.texnodom25.ru/typo3/index.ph ... 5Blang%5D=
I decided to fix the problem using the backup, but the database and file recovery does not resolve the problem. Prompt me, how deep can be the problem?, will be hurt because of this error, reinstall Typo3 cms
velo
Re: Invalid locale ""
Post by velo » 01 Mar 2017, 14:08
the Invalid locale "" exception is caused by the typo3 update.
We get the same error after update TYPO3 from 7.6.15 to 7.6.16
27bit.ru
Post by 27bit.ru » 01 Mar 2017, 14:19
velo wrote:Hi,
thanks for the info friend.
Someone help this?
https://aimeos.org/fileadmin/download/a ... 0-pre5.zip
I do not.
When about to be a solution to this problem?
Post by aimeos » 02 Mar 2017, 14:58
If you uploaded and installed the .zip file via the Extension Manager, you have to log out first.
In case you've unpacked the .zip file on the command line, it might be necessary to clear all caches too (in doubt, remove the typo3temp/Cache/ directory)
