Export file xml Template
27bit.ru
Post by 27bit.ru » 06 Mar 2017, 02:10
Hey. Is it possible to change the template of the exported file. Add any data, or delete any fields. Is it possible to do this using settings, or by changing the file?
Re: Export file xml Template
Post by aimeos » 06 Mar 2017, 15:35
You can copy and modify this template in your own extension:
https://github.com/aimeos/ai-controller ... efault.xml
27bit.ru
Post by 27bit.ru » 07 Mar 2017, 14:54
aimeos wrote:You can copy and modify this template in your own extension:
Thank you. Everything worked out. I just do not understand how I can display a link to the product page, and the catalog id, as well as the label of the catalog. Is it possible to add them to the export xml file?
Post by aimeos » 08 Mar 2017, 10:26
For links, you can use the "$this->url()" view helper like there:
https://github.com/aimeos/ai-controller ... lt.xml#L22
The catalog data isn't available by default. You have to create your own class extend from the "Standard" class and overwrite the export() method:
https://github.com/aimeos/ai-controller ... d.php#L273
