Translating Strings with line-breaks in Typoscript
pixls
Post by pixls » 04 Apr 2017, 08:17
Hi
Im using the PrePay payment provider. In the mail the user receives there is a string about the order number which should be included in the transaction. Its this one here:
$msg = $this->translate( 'client', 'Thank you for your order %1$s from %2$s.
The order is pending until we receive the final payment. If you\'ve chosen to pay in advance, please transfer the money to our bank account with the order ID %1$s as reference.' );
If you try to translate that normally via the TypoScipt field in the scheduler task you get a error about incorrect TypoScript code. But if you remove the new line it does not recognize it as a translatable string. So what can I do here?
Re: Translating Strings with line-breaks in Typoscript
Post by aimeos » 04 Apr 2017, 12:49
Did you try to replace the new line characters by the "\n" escape sequence?
