How to create admin user after first install bundle ?
ksicinski
Post by ksicinski » 06 Jul 2017, 09:57
or
How to create user and give him privilege to be admin?
Re: How to create admin user after first install bundle ?
Post by aimeos » 06 Jul 2017, 15:52
That highly depends on your used authentication configuration. Please have a look into the Symfony documentation for a deeper insight into authentication.
An example for setting up the FOS user bundle is described here:
https://aimeos.org/docs/Symfony/Configu ... ndle_login
There you can set up an admin account executing this command:
bin/console aimeos:account --admin <your email>
ksicinski
Post by ksicinski » 10 Jul 2017, 20:44
I add this configuration and stop at lat command line ;/
./bin/console fos:user:promote <email address> ROLE_ADMIN
I got this error:
[Doctrine\ORM\Mapping\MappingException]
Duplicate definition of column 'salt' on entity 'Aimeos\ShopBundle\Entity\FosUser' in a field or discriminator column mapping.
any tips?
Post by aimeos » 11 Jul 2017, 12:39
I got this error:
We've release the new 2017.07 version today. Can you please update to that version and set up authentication like described in the documentation?
https://github.com/aimeos/aimeos-symfony#installation
Then, things should work as expected when using fos:user:promote
ksicinski
Post by ksicinski » 11 Jul 2017, 19:07
Your update help.
I have only one remark this is bad lousy solution:
composer update --no-dev
I can forgot add this --no-dev parameters and add some new bundle and make update at production server this maibe crashed prod shop ;/
I thin better option will be create symfony console command to run all method hidden in this --no-dev parameters and add to manual information to run this command if user want install dev items.
Post by aimeos » 12 Jul 2017, 09:57
To be more precise, it should be
SYMFONY_ENV=prod composer update --no-dev
like stated in the installation documentation at GitHub
