Error in list page - Some mandatory parameters are missing
ksicinski
Post by ksicinski » 06 Jul 2017, 10:00
After install bundle and configur it with manual i go to page list and get this error:
Some mandatory parameters are missing ("resource") to generate a URL for route "aimeos_shop_jsonapi_get".
What is missing ?
Re: Error in list page - Some mandatory parameters are missi
Post by aimeos » 06 Jul 2017, 15:54
Can you please run "composer update" to ensure that you have the latest version?
Till yesterday there could be a mix of 2017.04 and 2017.07 packages that cause this error.
ksicinski
Post by ksicinski » 07 Jul 2017, 10:12
I made update and now have newes version your bundle but now i get another error:
Unable to add function "aiconfig" as extensions have already been initialized.
Any tips hov to fix it?
Post by aimeos » 07 Jul 2017, 12:05
When do you get this problem?
A test installation using version 2017.04 doesn't show any problems out of the box
ksicinski
Post by ksicinski » 07 Jul 2017, 12:53
After manual remove cache problem disappeared.
