[Error] Parameter "id" for route "aimeos_shop_jqadm_get"
ksicinski
Post by ksicinski » 11 Jul 2017, 20:54
When I login to admin panel and select from nav "catalog" I'm refirect to this path:
/app_dev.php/admin/default/jqadm/search/catalog?lang=pl
and I get error:
Parameter "id" for route "aimeos_shop_jqadm_get" must match "[0-9A-Z\-\_]+" ("_id_" given) to generate a corresponding URL.
Any tips?
Re: [Error] Parameter "id" for route "aimeos_shop_jqadm_get"
Post by aimeos » 12 Jul 2017, 10:50
Thank you for the hint. There was a wrong restriction in the JQAdm routes causing this error. Please run
SYMFONY_ENV=prod composer update --no-dev
to get the new version.
