order/ display and upgrate
Seds
Post by Seds » 11 Aug 2018, 13:35
hi,
i entered un new order with my count admin role.
in dashboard, i can see my order, and when i click on it, i can go to its order page /jqadm/save/order?id=1
but when i go to orders list page /jqadm/search/order?lang=fr, my last order doesn't appeared
and on /jqadm/save/order?id=1, when i want to save :
 Erreur An exception occurred while executing ' UPDATE "mshop_order_base_service_attr" SET "attrid" = '', "ordservid" = 2, "type" = '', "code" = 'directdebit.accountno', "value" = '\"475475475\"', "quantity" = 1, "name" = '', "mtime" = '2018-08-11 13:33:14', "editor" = 'xxx@gmail.com' WHERE "siteid" = 1 AND "id" = 5 ': SQLSTATE[23000]: Integrity constraint violation: 1062 Duplicata du champ '2---directdebit.accountno' pour la clef 'unq_msordbaseat_oid_aid_ty_cd', C:\wamp64\www\shop\vendor\aimeos\aimeos-core\lib\mwlib\src\MW\DB\Statement\DBAL\Simple.php:97
Re: order/ display and upgrate
Post by aimeos » 11 Aug 2018, 15:42
Can you post screenshots of what you did to get the error?
Seds
Post by Seds » 12 Aug 2018, 11:48
Post by aimeos » 13 Aug 2018, 07:51
Seems like a stored basket without an invoice so it's not displayed in the list view.
Can you also post the lower half of the screen where we can see the rest of the order?
How did you create that order?
