aimeos installation
aimeos installation
Hello all,
I have install aimeos bundle on symfony 3.4, I have follow all the step in the manual but when I try to access to : http://127.0.0.1:8000/app_dev.php/admin or http://127.0.0.1:8000/app_dev.php/list
I have this error :
Unable to find template "AimeosShopBundle:Catalog:list.html.twig" (looked into: /home/gui/Projets/graphe/app/Resources/views, /home/gui/Projets/graphe/vendor/symfony/symfony/src/Symfony/Bridge/Twig/Resources/views/Form).
I have miss something ?
Thank's in advance.
Guillaume
I have this error :
Thank's in advance.
Guillaume
Re: aimeos installation
Did you follow the installation guide step by step?
https://github.com/aimeos/aimeos-symfony#installation
Please have a look especially at your ./app/config/config.yml where you have to add this below the framework node:
Note that each indention must consist of four spaces!
templating:
engines: ['twig']
