error on install sample data
macubex
Post by macubex » 17 Jun 2019, 18:36
i have try install sample data with this command: php bin/console aimeos:setup
i have return:
SQLSTATE[42000]: Syntax error or access violation: 1071 Specified key was too long; max key length is 767 bytes
https://imgur.com/RxFO7q2
how i can reasolve?
Re: error on install sample data
Post by aimeos » 18 Jun 2019, 07:40
This is an MySQL < 5.7.8 issue in combination with utf8mb4. You should set the character set to utf8 and your collation to utf8_bin instead in your config: https://github.com/aimeos/aimeos-symfon ... op.yml#L30
Note: You have to recreate your tables afterwards
macubex
Post by macubex » 18 Jun 2019, 07:53
aimeos wrote:This is an MySQL < 5.7.8 issue in combination with utf8mb4. You should set the character set to utf8 and your collation to utf8_bin instead in your config: https://github.com/aimeos/aimeos-symfon ... op.yml#L30
works it, thanks!
johnsmith101
Post by johnsmith101 » 17 Sep 2019, 09:07
Ok.
And how to install sample data using zip if already downloaded without CLI?
Post by aimeos » 17 Sep 2019, 09:55
The sample data is included in the package (no separate zip file) and you can install it using:
php bin/console aimeos:setup --option=setup/default/demo:1
