Symofny 4.3.2 install error
mluksor
Post by mluksor » 24 Jul 2019, 15:36
I have problem when I install aimeos bundle on symfony 4.3.2 I received error: The service "fos_user.user_manager" has a dependency on a non-existent service "doctrine".
Has anyone seen such a problem? please help
Re: Symofny 4.3.2 install error
Post by aimeos » 24 Jul 2019, 20:07
That doesn't seem to be related to Aimeos. If you set up Symfony 4.3 and Aimeos like described in the docs (https://github.com/aimeos/aimeos-symfon ... #symfony-4), everything is fine.
Maybe a composer package is missing in your installation or an old version is used. Here are the packages that are installed when using the step by step guide (using PHP 7.2):
aimeos/ai-admin-jqadm               2019.07.4 Aimeos ai-admin-jqadm extension
aimeos/ai-admin-jsonadm             2019.07.1 Aimeos ai-admin-jsonadm extension
aimeos/ai-client-html               2019.07.5 Aimeos ai-client-html extension
aimeos/ai-client-jsonapi            2019.07.1 Aimeos JSON API extension
aimeos/ai-controller-frontend       2019.07.2 Aimeos ai-controller-frontend extension
aimeos/ai-controller-jobs           2019.07.3 Aimeos ai-controller-jobs extension
aimeos/ai-fosuser                   2019.07.1 Aimeos ai-fosuser extension
aimeos/ai-gettext                   2019.07.1 Aimeos Gettext extension
aimeos/ai-monolog                   2019.07.1 Monolog adapter for Aimeos web shops an...
aimeos/ai-swiftmailer               2019.07.1 SwiftMailer adapter for Aimeos web shop...
aimeos/ai-symfony                   2019.07.1 Symfony 2 adapter for Aimeos web shops ...
aimeos/ai-twig                      2019.07.1 Twig template engine adapter for Aimeos...
aimeos/aimeos-core                  2019.07.6 Full-featured e-commerce components for...
aimeos/aimeos-symfony               2019.07.1 Professional, full-featured and high pe...
composer/installers                 v1.6.0    A multi-framework Composer library inst...
doctrine/annotations                v1.6.1    Docblock Annotations Parser
doctrine/cache                      v1.8.0    Caching library offering an object-orie...
doctrine/collections                v1.6.2    PHP Doctrine Collections library that a...
doctrine/common                     v2.10.0   PHP Doctrine Common project is a librar...
doctrine/dbal                       v2.9.2    Powerful PHP database abstraction layer...
doctrine/doctrine-bundle            1.11.2    Symfony DoctrineBundle
doctrine/doctrine-cache-bundle      1.3.5     Symfony Bundle for Doctrine Cache
doctrine/doctrine-migrations-bundle v2.0.0    Symfony DoctrineMigrationsBundle
doctrine/event-manager              v1.0.0    Doctrine Event Manager component
doctrine/inflector                  v1.3.0    Common String Manipulations with regard...
doctrine/instantiator               1.2.0     A small, lightweight utility to instant...
doctrine/lexer                      1.0.2     PHP Doctrine Lexer parser library that ...
doctrine/migrations                 v2.1.0    PHP Doctrine Migrations project offer a...
doctrine/orm                        v2.6.3    Object-Relational-Mapper for PHP
doctrine/persistence                1.1.1     The Doctrine Persistence project is a s...
doctrine/reflection                 v1.0.0    Doctrine Reflection component
easycorp/easy-log-handler           v1.0.7    A handler for Monolog that optimizes lo...
egulias/email-validator             2.1.10    A library for validating emails against...
fig/link-util                       1.0.0     Common utility implementations for HTTP...
friendsofsymfony/user-bundle        v2.1.2    Symfony FOSUserBundle
jdorn/sql-formatter                 v1.2.17   a PHP SQL highlighting library
monolog/monolog                     1.24.0    Sends your logs to files, sockets, inbo...
nikic/php-parser                    v4.2.2    A PHP parser written in PHP
nyholm/psr7                         1.1.0     A fast PHP7 implementation of PSR-7
ocramius/package-versions           1.5.1     Composer plugin that provides efficient...
ocramius/proxy-manager              2.2.2     A library providing utilities to genera...
php-http/message-factory            v1.0.2    Factory interfaces for PSR-7 HTTP Message
phpdocumentor/reflection-common     1.0.1     Common reflection classes used by phpdo...
phpdocumentor/reflection-docblock   4.3.1     With this component, a library can prov...
phpdocumentor/type-resolver         0.4.0
psr/cache                           1.0.1     Common interface for caching libraries
psr/container                       1.0.0     Common Container Interface (PHP FIG PSR...
psr/http-factory                    1.0.1     Common interfaces for PSR-7 HTTP messag...
psr/http-message                    1.0.1     Common interface for HTTP messages
psr/link                            1.0.0     Common interfaces for HTTP links
psr/log                             1.1.0     Common interface for logging libraries
sensio/framework-extra-bundle       v5.4.1    This bundle provides a way to configure...
swiftmailer/swiftmailer             v6.2.1    Swiftmailer, free feature-rich PHP mailer
symfony/asset                       v4.3.2    Symfony Asset Component
symfony/browser-kit                 v4.3.2    Symfony BrowserKit Component
symfony/cache                       v4.3.2    Symfony Cache component with PSR-6, PSR...
symfony/cache-contracts             v1.1.5    Generic abstractions related to caching
symfony/config                      v4.3.2    Symfony Config Component
symfony/console                     v4.3.2    Symfony Console Component
symfony/css-selector                v4.3.2    Symfony CssSelector Component
symfony/debug                       v4.3.2    Symfony Debug Component
symfony/debug-bundle                v4.3.2    Symfony DebugBundle
symfony/debug-pack                  v1.0.7    A debug pack for Symfony projects
symfony/dependency-injection        v4.3.2    Symfony DependencyInjection Component
symfony/doctrine-bridge             v4.3.2    Symfony Doctrine Bridge
symfony/dom-crawler                 v4.3.2    Symfony DomCrawler Component
symfony/dotenv                      v4.3.2    Registers environment variables from a ...
symfony/event-dispatcher            v4.3.2    Symfony EventDispatcher Component
symfony/event-dispatcher-contracts  v1.1.5    Generic abstractions related to dispatc...
symfony/expression-language         v4.3.2    Symfony ExpressionLanguage Component
symfony/filesystem                  v4.3.2    Symfony Filesystem Component
symfony/finder                      v4.3.2    Symfony Finder Component
symfony/flex                        v1.4.5    Composer plugin for Symfony
symfony/form                        v4.3.2    Symfony Form Component
symfony/framework-bundle            v4.3.2    Symfony FrameworkBundle
symfony/http-client                 v4.3.2    Symfony HttpClient component
symfony/http-client-contracts       v1.1.5    Generic abstractions related to HTTP cl...
symfony/http-foundation             v4.3.2    Symfony HttpFoundation Component
symfony/http-kernel                 v4.3.2    Symfony HttpKernel Component
symfony/inflector                   v4.3.2    Symfony Inflector Component
symfony/intl                        v4.3.2    A PHP replacement layer for the C intl ...
symfony/maker-bundle                v1.12.0   Symfony Maker helps you create empty co...
symfony/mime                        v4.3.2    A library to manipulate MIME messages
symfony/monolog-bridge              v4.3.2    Symfony Monolog Bridge
symfony/monolog-bundle              v3.4.0    Symfony MonologBundle
symfony/options-resolver            v4.3.2    Symfony OptionsResolver Component
symfony/orm-pack                    v1.0.6    A pack for the Doctrine ORM
symfony/phpunit-bridge              v4.3.2    Symfony PHPUnit Bridge
symfony/polyfill-intl-icu           v1.11.0   Symfony polyfill for intl's ICU-related...
symfony/polyfill-intl-idn           v1.11.0   Symfony polyfill for intl's idn_to_asci...
symfony/polyfill-mbstring           v1.11.0   Symfony polyfill for the Mbstring exten...
symfony/polyfill-php72              v1.11.0   Symfony polyfill backporting some PHP 7...
symfony/polyfill-php73              v1.11.0   Symfony polyfill backporting some PHP 7...
symfony/process                     v4.3.2    Symfony Process Component
symfony/profiler-pack               v1.0.4    A pack for the Symfony web profiler
symfony/property-access             v4.3.2    Symfony PropertyAccess Component
symfony/property-info               v4.3.2    Symfony Property Info Component
symfony/psr-http-message-bridge     v1.2.0    PSR HTTP message bridge
symfony/routing                     v4.3.2    Symfony Routing Component
symfony/security-bundle             v4.3.2    Symfony SecurityBundle
symfony/security-core               v4.3.2    Symfony Security Component - Core Library
symfony/security-csrf               v4.3.2    Symfony Security Component - CSRF Library
symfony/security-guard              v4.3.2    Symfony Security Component - Guard
symfony/security-http               v4.3.2    Symfony Security Component - HTTP Integ...
symfony/serializer                  v4.3.2    Symfony Serializer Component
symfony/serializer-pack             v1.0.2    A pack for the Symfony serializer
symfony/service-contracts           v1.1.5    Generic abstractions related to writing...
symfony/stopwatch                   v4.3.2    Symfony Stopwatch Component
symfony/swiftmailer-bundle          v3.2.8    Symfony SwiftmailerBundle
symfony/templating                  v4.3.2    Symfony Templating Component
symfony/test-pack                   v1.0.6    A pack for functional and end-to-end te...
symfony/translation                 v4.3.2    Symfony Translation Component
symfony/translation-contracts       v1.1.5    Generic abstractions related to transla...
symfony/twig-bridge                 v4.3.2    Symfony Twig Bridge
symfony/twig-bundle                 v4.3.2    Symfony TwigBundle
symfony/validator                   v4.3.2    Symfony Validator Component
symfony/var-dumper                  v4.3.2    Symfony mechanism for exploring and dum...
symfony/var-exporter                v4.3.2    A blend of var_export() + serialize() t...
symfony/web-link                    v4.3.2    Symfony WebLink Component
symfony/web-profiler-bundle         v4.3.2    Symfony WebProfilerBundle
symfony/web-server-bundle           v4.3.2    Symfony WebServerBundle
symfony/yaml                        v4.3.2    Symfony Yaml Component
twig/twig                           v2.11.3   Twig, the flexible, fast, and secure te...
webmozart/assert                    1.4.0     Assertions to validate method input/out...
zendframework/zend-code             3.3.1     provides facilities to generate arbitra...
zendframework/zend-diactoros        1.8.6     PSR HTTP Message implementations
zendframework/zend-eventmanager     3.2.1     Trigger and listen to events within a P...
