Update 2019.10 Error
rasch
Post by rasch » 28 Oct 2019, 14:00
When updating Aimeos Shop from 2019.07.x-dev to 2019.10.1 with composer update I get the following SQL error message.
Checking table "mshop_subscription":
In Simple.php line 94:
SQLSTATE[42000]: Syntax error or access violation: 1064 You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax
to use near 'SMALLINT DEFAULT 0 NOT NULL, CHANGE `interval` `interval` VARCHAR(32) NOT NULL' at line 1: ALTER TABLE mshop_subscription ADD productid VARCHAR(36) NOT NULL, ADD perio
d SMALLINT DEFAULT 0 NOT NULL, CHANGE `interval` `interval` VARCHAR(32) NOT NULL
What can I do?
Thank your for your help.
aimeos: 2019.07.x-dev
symfony: 4.3
php: 7.2
ubuntu: 18
Re: Update 2019.10 Error
Post by aimeos » 28 Oct 2019, 14:14
Seems like the "period" column name is treated as a reserved word. Do you use MariaDB <= 10.3.6 in Oracle mode?
https://mariadb.com/kb/en/library/reser ... racle-mode
rasch
Post by rasch » 29 Oct 2019, 13:41
No, I use MariaDB 10.3.18 and the sql_mode is STRICT_TRANS_TABLES, ERROR_FOR_DIVISION_BY_ZERO, NO_AUTO_CREATE_USER, NO_ENGINE_SUBSTITUTION.
But the cause of the failure is nevertheless the unmasked identifier period. When I first excecute in the mysql shell the command ALTER TABLE mshop_subscription ADD productid VARCHAR (36) NOT NULL, ADD `period` SMALLINT DEFAULT 0 NOT NULL, CHANGE` interval` `interval` VARCHAR (32) NOT NULL; then composer update runs without error.
Is it possible to change the source code?
Post by aimeos » 29 Oct 2019, 13:56
We can't change the code because the SQL is generated by Doctrine DBAL and the problem must be somewhere around here:
https://github.com/doctrine/dbal/blob/2 ... m.php#L553
Does this also happen if you set up 2019.10 from scratch?
rasch
Post by rasch » 30 Oct 2019, 07:26
No.
The error does not occur with a new installation. It only occurs during an update.
