Multishop - Configuration
MSchrading
Post by MSchrading » 23 Jan 2020, 08:21
1. Backend
As user in admin-group in a specific site I want to setup my backend this way, that I can see all products and customers etc. from this site but not from other and not from the default site. This I can setup with sitelevel=2! But I'm not really shure how to config this. Could you please give me a hand where to setup this?
2.Frontend
Routing. Normaly when I call i.e. "myshop.com/shop" I'll get my first page with all products from all shops. Now I want to call only one specific shop with only products from this shop etc.
Would you please give me a hand how to setup the routes easily for all posible shops?
(Symfony 4.3, php7.2, Aimeos 2019.10, Ubuntu 18.04)
Thank you so much
Re: Multishop - Configuration
Post by aimeos » 24 Jan 2020, 09:27
MSchrading wrote: 23 Jan 2020, 08:21 2.Frontend
You have to adapt your routing for multiple shops:
https://aimeos.org/docs/Symfony/Configu ... iple_shops
MSchrading
Post by MSchrading » 24 Jan 2020, 09:52
Thanks a lot.
I tried this out before and when I use this but this produce this error:
An exception has been thrown during the rendering of a template ("Route pattern "/{site}/admin/{site}/jqadm/file/{type}" cannot reference variable name "site" more than once.")
Regards
nos3
Post by nos3 » 24 Jan 2020, 09:54
Hello
MSchrading wrote: 23 Jan 2020, 08:21 As user in admin-group in a specific site I want to setup my backend this way, that I can see all products and customers etc. from this site but not from other and not from the default site. This I can setup with sitelevel=2! But I'm not really shure how to config this. Could you please give me a hand where to setup this?
In your ./config/packages/aimeos_shop.yaml add
    mshop:
        // keep the existing lines
        locale:
            manager:
                standard:
                    sitelevel: 2
The indention must be exactly 4 spaces more for each level!
nos3
Post by nos3 » 24 Jan 2020, 09:55
MSchrading wrote: 24 Jan 2020, 09:52
You have to do this for the frontend only. The admin backend already has the {site} parameter included and if you add it again, you get the error above.
MSchrading
Post by MSchrading » 24 Jan 2020, 10:08
I set it exactly like you said.
In routes/aimeos_shop.yaml:
aimeos_shop:
resource: "@AimeosShopBundle/Resources/config/routing.yml"
prefix: /{site}/
defaults: { site: 'default' }
aimeos_shop_admin:
path: /admin
defaults: { _controller: AimeosShopBundle:Admin:index }
aimeos_shop_admin_check:
path: /admin_check
This will always extens the route with /admin/{site}/jqadm/file/{type}
mmmhh
