missing directory or files on composer update
Hi there.
When I start composer update composer stucks with this error:
Could not scan for classes inside "ext/ai-fosuser//lib/custom/src" which does not appear to be a file nor a folder
And this folder will be empty...
Symfony 4.3 php7.2 aimeos with multi mandants
Thank you for a quick help.
Michael
Michael
Re: missing diectory or files on composer update
Has been solved. ![Zwinkern ;-)](./images/smilies/icon_e_wink.gif)
