FosUserBundle
garwat82
FosUserBundle
Post by garwat82 » 26 Jan 2015, 14:35
Hey
I've managed to integrate the Symfony FosUserBundle (https://github.com/FriendsOfSymfony/FOSUserBundle) for registration, authentication and password reminder into my Aimeos Symfony project.
Are you also interested in using this in Aimeos instead of the current solution?
Regards,
Garret
Re: FosUserBundle
Post by aimeos » 26 Jan 2015, 15:36
Hi Garret
Sure, every contribution is welcome!
garwat82
Re: FosUserBundle
Post by garwat82 » 30 Jan 2015, 14:17
Hey
The necessary changes have been committed and as far as I can see, the tests for the core and the Symfony adapter succeed now.
There's a pull request for the Symfony bundle as well and it may require some more attention because I've only added the FosUser entity and that's no used by default.
Regards,
Garret
garwat82
Re: FosUserBundle
Post by garwat82 » 30 Jan 2015, 17:56
The test are now working like expected
Garret
Re: FosUserBundle
Post by aimeos » 30 Jan 2015, 18:19
Great! How does it work?
Maybe we can write some documentation for it.
garwat82
Re: FosUserBundle
Post by garwat82 » 30 Jan 2015, 19:47
I've used 2.0 branch of the FosUserBundle and I've added this to the require section of my composer.json:
"friendsofsymfony/user-bundle": "~2.0@dev"
In AppKernel::registerBundles() the bundle must be registered:
new FOS\UserBundle\FOSUserBundle(),
The config.yml needs these settings and I've used the secure Bcrypt encryption:
fos_user:
    db_driver: orm # other valid values are 'mongodb', 'couchdb' and 'propel'
    firewall_name: aimeos_myaccount
    user_class: Aimeos\ShopBundle\Entity\FosUser
aimeos_shop:
    classes:
        customer:
            manager:
    mshop:
        customer:
            manager:
                password:
The user bundle routes must also be included in the routing.yml:
fos_user:
    resource: "@FOSUserBundle/Resources/config/routing/all.xml"
The security.yml is the most complex file:
security:
    providers:
        aimeos_customer:
            entity: { class: AimeosShopBundle:FosUser, property: username }
    encoders:
        Aimeos\ShopBundle\Entity\FosUser: bcrypt
    firewalls:
        aimeos_myaccount:
            pattern: ^/
            form_login:
                provider: aimeos_customer
                csrf_provider: form.csrf_provider
            logout:       true
            anonymous:    true
    access_control:
        - { path: ^/login$, role: IS_AUTHENTICATED_ANONYMOUSLY }
        - { path: ^/register, role: IS_AUTHENTICATED_ANONYMOUSLY }
        - { path: ^/resetting, role: IS_AUTHENTICATED_ANONYMOUSLY }
        - { path: ^/myaccount, roles: ROLE_USER }
Hope this helps.
