MongoDB
AdamBlansett
MongoDB
Post by AdamBlansett » 12 Feb 2017, 17:07
Can I use the Doctrine MongoDB bundle with this to use MongoDB or am I required to use MySQL/Percona?
Symfony 2
I will try if no one has an answer.
The only true wisdom is in knowing you know nothing. - Socrates
adamblansett.com
Re: MongoDB
Post by aimeos » 13 Feb 2017, 10:15
MongoDB is currently not supported. You have the choice between those:
https://aimeos.org/docs/Developers/Libr ... se_support
seamus10
Re: MongoDB
Post by seamus10 » 24 Jan 2019, 12:42
AdamBlansett wrote:Can I use the Doctrine MongoDB bundle with this to use MongoDB or am I required to use MySQL/Percona?
Symfony 2
If each environment requires a different MongoDB connection URI, you can as a bundle is available that integrates the Doctrine MongoDB ODM into Symfony, making it easy to configure and use
Re: MongoDB
Post by aimeos » 25 Jan 2019, 07:47
Aimeos doesn't use Doctrine ORM because it's too slow if you have many products
