Need to change the database schema
Re: Need to change the database schema
I thought that you need to add more parameters to php artisan aimeos:setup for it to install the demo data.
I don't want to install the demo data, just run database migrations, this is also required if I make changes to the ElasticSearch config, like max_result_window. php artisan aimeos:setup updates the ElasticSearch index config.
I want customers to be able to add multiple reviews to the same product and not have to remove that database change when it's required to execute the php artisan aimeos:setup command.
Is here no way to override vendor/aimeos/aimeos-core/setup/default/schema/review.php so that php artisan aimeos:setup reads from the overriden file itself?
So far the only thing I've come up with is changing the original file:
This works, but if there is an update, the changes to this file will be removed, and I will get "Integrity constraint violation" again, and I will have to modify the original file again, which I want to avoid and override it instead.
You can add a setup/default/schema/review.php file in your own Aimeos extension and there, you can remove the unique index:
https://github.com/aimeos/aimeos-core/b ... ew.php#L28
This should be done before the table migration is executed.
$this->dropIndex( 'mshop_review', 'unq_msrev_cid_dom_rid_sid' );
