how can get Bestsellers or Most Popular products?
Ahmad
Re: how can get Bestsellers or Most Popular products?
Post by Ahmad » 12 Nov 2020, 08:39
@aimeos
how can I get just top 10 product, I mean I want to query that sent to mysql just get top 10 not all products?
Post by aimeos » 13 Nov 2020, 13:08
You can use slice():
$cntl = \Aimeos\Controller\Frontend::create( $context, 'product' );
$items = $cntl->use( ['text', 'price', 'media'] )->product( <ids> )->slice( 0, 10 )->search();
See: https://github.com/aimeos/ai-controller ... #L158-L175
peter69
Post by peter69 » 21 Oct 2022, 22:28
In case it is useful to anyone, I have made the following function to return the best-selling products. It works with the latest version (2022.07.2) of Laravel Aimeos to date.
public function getBestSellersByCategory ($categoryID, $domains, $context, $limit = 10) {
        $manager = \Aimeos\MShop::create( $context, 'order/base/product' );
        $result = $manager->aggregate(
            $manager->filter(),
            'order.base.product.productid', 'order.base.product.quantity', 'sum'
        )->slice( 0, $limit );
        // find the products which are sold most in $result (product ID is the key, count is the value)
        return $cntl
                    ->uses( $domains )
                    ->category([$categoryID])
                    ->product( $result->keys()->toArray() )
                    ->search();
This function must be in a decorator.
Regards,
Post by aimeos » 24 Oct 2022, 17:31
Very cool! :D
peter69
Post by peter69 » 24 Oct 2022, 22:13
Thanks!!! :))
loeffe1
Post by loeffe1 » 20 Mar 2023, 08:30
I have created a decorator in \Aimeos\MShop\Service\Provider\Decorator and included this function, but how can I use it? Aren't decorators configured via the Services tab and limited to Delivery and Payment?
Post by aimeos » 21 Mar 2023, 08:04
A service decorator is the wrong place because it's only used for delivery/payment options as you've already stated.
Create a HTML client decorator for the component you want (e.g. catalog/lists) instead:
https://aimeos.org/docs/latest/frontend ... omponents/
