Modify users table
yong
Re: Modify users table
Post by yong » 23 Jul 2019, 16:02
The mshop_customer and mshop_customer_list are empty but i don't understand why i've a constraint violation !
Please help !
Post by aimeos » 23 Jul 2019, 21:08
You've probably extended from the Standard class, not from the Laravel class. The Standard class refers in its lists and property sub-manager to the mshop_customer_* tables instead of the users_* tables.
yong
Post by yong » 24 Jul 2019, 07:57
Hi ! when i execute artisan aimeos:setup , there's not any error but in the database some columns have wrong data ( for example i've not any data in the 'email' column , the columns 'company' and 'website' have the email and some others columns are wrong )
Post by aimeos » 24 Jul 2019, 19:40
The bind() calls in our saveItem() method doesn't correspond to your SQL statement in your config
Post by aimeos » 21 Aug 2019, 13:41
Starting with the upcoming 2019.10 release, managing custom columns will be super easy.
Extend the table (like already available) in ./ext/<your_extension>/lib/custom/setup/default/schema/customer.php:
return array(
	'table' => array(
		'users' => function ( \Doctrine\DBAL\Schema\Schema $schema ) {
			$table = $schema->getTable( 'users' );
			$table->addColumn( 'mycolumn', 'string', array( 'length' => 64 ) );
			return $schema;
Extend the customer manager by the 'mycolumn' column in ./ext/<your_extension>/lib/custom/src/MShop/Customer/Manager/Decorator/Myproject.php:
namespace Aimeos\MShop\Customer\Manager\Decorator;
class Myproject
	extends \Aimeos\MShop\Common\Manager\Decorator\Base
	private $attr = [
		'mycolumn' => [
			'code' => 'mycolumn',
			'internalcode' => 'mcus."mycolumn"',
			'internaltype' => \Aimeos\MW\DB\Statement\Base::PARAM_STR,
	public function getSaveAttributes()
		return parent::getSaveAttributes() + $this->createAttributes( $this->attr );
	public function getSearchAttributes( $withsub = true )
		return parent::getSearchAttributes( $withsub ) + $this->createAttributes( $this->attr );
Configure the new decorator in ./config/shop.php (mshop section):
	'mshop' => [
		'customer' => [
			'manager' => [
				'decorator' => [
					'local' => ['Myproject']
Aimeos cares about storing and retrieving the data automatically without any further code. Now you can do:
$manager = \Aimeos\MShop::create( $context, 'customer' );
$item = $manager->createItem()->set( 'mycolumn', 'myvalue' );
$item = $manager->saveItem( $item );
$search->setConditions( $search->compare( '==', 'mycolumn', 'myvalue' ) );
foreach( $manager->searchItems( $search ) as $item ) {
	echo $item->get( 'mycolumn', 'default value' );
