Add price after pressing "add to basket" button
Re: Add price after pressing "add to basket" button
Post by aimeos » 23 Aug 2019, 06:59
The parameters are read-only. You have to retrieve all, change the one you need and setup the view helper again:
$params = $view->param();
$params['b_prod'] = [/* modified array */];
$view->addHelper( 'param', new \Aimeos\MW\View\Helper\Param\Standard( $view, $params );
lucadambros
Post by lucadambros » 23 Aug 2019, 10:19
Sorry I have another question:
how can I clone the product and change the price of it?
I have the product
    $productManager = \Aimeos\MShop::create( $context, 'product' );
    $item = $productManager->getItem( $params['b_prod'][0]['prodid'], ['media', 'price', 'text'] );
Now what I have to do?
Thank you very much
Post by aimeos » 24 Aug 2019, 09:04
    $priceManager = \Aimeos\MShop::create( $context, 'price' );
    $item = $productManager->getItem( $view->param( 'b_prod/0/prodid' ), ['media', 'price', 'text'] );
    $listItem = $productManager->createListItem()->setType( 'default' );
    $priceItem = $priceManager->createItem()->setType( 'default' )->setCurrencyId( 'EUR' );
    $item->addListItem( 'price', $listItem, $refItem );
Here's the interface: https://github.com/aimeos/aimeos-core/b ... /Iface.php
lucadambros
Post by lucadambros » 26 Aug 2019, 06:57
I got this error:
Aimeos \ MShop \ Exception
Unable to call method "createListItem"
EDIT: the function is createListsItem not createListItem
lucadambros
Post by lucadambros » 26 Aug 2019, 07:07
I got another error:
Call to undefined method Aimeos\MShop\Price\Item\Standard::setCurrency()
EDIT: the function is SetCurrencyId
lucadambros
Post by lucadambros » 27 Aug 2019, 07:20
I created the decorator. I tried to clone the product and sending the new ID to the AddProduct function. The product is in the db correctly but I am getting an error.
I wrote this code:
$mediaManager = \Aimeos\MShop::create( $context, 'media' );
$item = $productManager->getItem( $view->param( 'b_prod/0/prodid' ), ['media', 'price', 'text']);
$listItem = $productManager->createListsItem()->setType( 'default' );
$priceItem = $priceManager->createItem()->setType( 'default' )->setCurrencyId( 'EUR' )->setValue(5);
$mediaItem = $item->getRefItems('media', 'default');
$mediaItem = array_values($mediaItem)[0];
$clone_item = $productManager->createItem();
$clone_item->addListItem( 'price', $listItem, $priceItem);
$clone_item->addListItem( 'media', $listItem, $mediaItem);
$productManager->saveItem($clone_item);
$tmp = $clone_item->toArray();
$params['b_prod'] = [["prodid"=> $tmp["product.id"], "quantity"=>"1"]];
$view->addHelper( 'param', new \Aimeos\MW\View\Helper\Param\Standard( $view, $params ));
I am getting this error:
Adding product with ID "95" is not allowed
The ID "95" is the new product. Why I am getting this error?
Post by aimeos » 27 Aug 2019, 07:56
Your product has no category assigned and that's required when using the basket frontend controller.
lucadambros
Post by lucadambros » 27 Aug 2019, 08:07
How can I assign it?
(it must be the same as the original)
lucadambros
Post by lucadambros » 27 Aug 2019, 10:09
i also wrote this:
$clone_item->addListItem( 'catalog', $listItem, $catalogManager->getItem(1));
but I got basket empty
Seems like the file ext/ai-client-html/client/html/src/Client/Html/Basket/Standard/Standard.php is not getting the product in the line
// the list has the right ID
$products = $productCntl->product( $list )->slice( 0, count( $list ) )->search();
Post by aimeos » 27 Aug 2019, 14:35
You have to create the product in the backend first and can't create a product on the fly. There are dependencies that require the product in the database.
Alternatively, if all your products can be bought, you can remove the Category frontend basket decorator:
https://aimeos.org/docs/Configuration/C ... tors/local
