Foreign Key on Setup
jim1506
Re: Foreign Key on Setup
Post by jim1506 » 03 Sep 2019, 10:02
Ok. I dropped all the tables and re-ran php artisan migrate.
I then ran
and got the error message
Aimeos\MW\DB\Exception : SQLSTATE[HY000]: General error: 1005 Can't create table `tdbhosti_demoshop`.`users_address` (errno: 150 "Foreign key constraint is incorrectly formed")
jim1506
Post by jim1506 » 03 Sep 2019, 10:03
sorry I should have mentioned I changed the structure of user so id was unsigned
jim1506
Post by jim1506 » 03 Sep 2019, 12:00
I have done that - redone the migration - changed the unsigned on users.
When I run
I get
Post by aimeos » 03 Sep 2019, 12:12
Please make sure the users.id and user_address.parentid columns are of the same type and length:
https://stackoverflow.com/questions/843 ... rmed-error
jim1506
Post by jim1506 » 03 Sep 2019, 13:48
They are:
users:
id` int(10) unsigned NOT NULL AUTO_INCREMENT,
users_address
`parentid` int(10) unsigned NOT NULL,
The only difference is auto increment
Post by aimeos » 04 Sep 2019, 07:23
You can try
SHOW ENGINE INNODB STATUS
to show the last InnoDB foreign key error. This can maybe yield more information about the problem:
https://mariadb.com/kb/en/library/show- ... db-status/
jim1506
Post by jim1506 » 04 Sep 2019, 08:57
Same reply as the laravel error
nhakhtn
Post by nhakhtn » 16 Jul 2022, 02:51
you should go to table `users` then change the type of table from MyISAM to InnoDB, then it will be solved!
