Tax rate for each product
MikaelNazarenko
Expert
Re: Tax rate for each product
Post by MikaelNazarenko » 18 Oct 2019, 21:35
This is the point where I get the error when trying to send email with cron or manually:
https://github.com/aimeos/aimeos-core/b ... e.php#L317
Please, check it. I am not sure but seems some changes were made to addresses after last aimeos updates.
In my case it tries to get payment address with position = 0; But $this->addresses is empty array in my case. But why empty array ? Payment address is set ...
Thank you a lot for support and great responsibility !
Post by aimeos » 19 Oct 2019, 17:21
Can you please post the stack trace of the exception as well?
MikaelNazarenko
Expert
Post by MikaelNazarenko » 20 Oct 2019, 08:45
Hmmm, now I made test order on my local development shop with prepay payment service. Then I executed manually:
php /var/www/schmuck/artisan aimeos:jobs "order/email/delivery order/email/payment order/email/voucher order/service/delivery"
And now I got another problem, and seems it is not touched to my customization:
Call to a member function getTaxValue() on array#0 /var/www/schmuck/vendor/aimeos/aimeos-core/lib/mwlib/src/MW/View/Standard.php(257): include()
#1 /var/www/schmuck/vendor/aimeos/aimeos-core/lib/mwlib/src/MW/View/Standard.php(239): Aimeos\MW\View\Standard->includeFile('/var/www/schmuc...')
#2 /var/www/schmuck/vendor/aimeos/aimeos-core/lib/mwlib/src/MW/View/Helper/Partial/Standard.php(36): Aimeos\MW\View\Standard->render('email/common/te...')
#3 [internal function]: Aimeos\MW\View\Helper\Partial\Standard->transform('email/common/te...', Array)
#4 /var/www/schmuck/vendor/aimeos/aimeos-core/lib/mwlib/src/MW/View/Standard.php(88): call_user_func_array(Array, Array)
#5 /var/www/schmuck/ext/ai-client-html/client/html/templates/email/payment/text-body-standard.php(76): Aimeos\MW\View\Standard->__call('partial', Array)
#6 /var/www/schmuck/vendor/aimeos/aimeos-core/lib/mwlib/src/MW/View/Standard.php(257): include('/var/www/schmuc...')
#7 /var/www/schmuck/vendor/aimeos/aimeos-core/lib/mwlib/src/MW/View/Standard.php(239): Aimeos\MW\View\Standard->includeFile('/var/www/schmuc...')
#8 /var/www/schmuck/ext/ai-client-html/client/html/src/Client/Html/Email/Payment/Text/Standard.php(107): Aimeos\MW\View\Standard->render('email/payment/t...')
#9 /var/www/schmuck/ext/ai-client-html/client/html/src/Client/Html/Email/Payment/Standard.php(96): Aimeos\Client\Html\Email\Payment\Text\Standard->getBody('')
#10 /var/www/schmuck/ext/ai-client-html/controller/jobs/src/Controller/Jobs/Order/Email/Payment/Standard.php(262): Aimeos\Client\Html\Email\Payment\Standard->getBody()
#11 /var/www/schmuck/ext/ai-client-html/controller/jobs/src/Controller/Jobs/Order/Email/Payment/Standard.php(225): Aimeos\Controller\Jobs\Order\Email\Payment\Standard->processItem(Object(Aimeos\Client\Html\Email\Payment\Standard), Object(Aimeos\MShop\Order\Item\Standard), Object(Aimeos\MShop\Order\Item\Base\Standard), Object(Aimeos\MShop\Order\Item\Base\Address\Address))
#12 /var/www/schmuck/ext/ai-client-html/controller/jobs/src/Controller/Jobs/Order/Email/Payment/Standard.php(129): Aimeos\Controller\Jobs\Order\Email\Payment\Standard->process(Object(Aimeos\Client\Html\Email\Payment\Standard), Array, 4)
#13 /var/www/schmuck/vendor/aimeos/aimeos-laravel/src/Aimeos/Shop/Command/JobsCommand.php(69): Aimeos\Controller\Jobs\Order\Email\Payment\Standard->run()
#14 [internal function]: Aimeos\Shop\Command\JobsCommand->Aimeos\Shop\Command\{closure}(Object(Aimeos\MShop\Context\Item\Standard), Object(Aimeos\Bootstrap), 'order/email/pay...')
#15 /var/www/schmuck/vendor/aimeos/aimeos-core/lib/mwlib/src/MW/Process/Pcntl.php(177): call_user_func_array(Object(Closure), Array)
#16 /var/www/schmuck/vendor/aimeos/aimeos-core/lib/mwlib/src/MW/Process/Pcntl.php(112): Aimeos\MW\Process\Pcntl->exec(Object(Closure), Array)
#17 /var/www/schmuck/vendor/aimeos/aimeos-core/lib/mwlib/src/MW/Process/Decorator/Check.php(61): Aimeos\MW\Process\Pcntl->start(Object(Closure), Array, true)
#18 /var/www/schmuck/vendor/aimeos/aimeos-laravel/src/Aimeos/Shop/Command/JobsCommand.php(72): Aimeos\MW\Process\Decorator\Check->start(Object(Closure), Array, true)
#19 [internal function]: Aimeos\Shop\Command\JobsCommand->handle()
#20 /var/www/schmuck/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(32): call_user_func_array(Array, Array)
#21 /var/www/schmuck/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(90): Illuminate\Container\BoundMethod::Illuminate\Container\{closure}()
#22 /var/www/schmuck/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(34): Illuminate\Container\BoundMethod::callBoundMethod(Object(Illuminate\Foundation\Application), Array, Object(Closure))
#23 /var/www/schmuck/vendor/laravel/framework/src/Illuminate/Container/Container.php(576): Illuminate\Container\BoundMethod::call(Object(Illuminate\Foundation\Application), Array, Array, NULL)
#24 /var/www/schmuck/vendor/laravel/framework/src/Illuminate/Console/Command.php(183): Illuminate\Container\Container->call(Array)
#25 /var/www/schmuck/vendor/symfony/console/Command/Command.php(255): Illuminate\Console\Command->execute(Object(Symfony\Component\Console\Input\ArgvInput), Object(Illuminate\Console\OutputStyle))
#26 /var/www/schmuck/vendor/laravel/framework/src/Illuminate/Console/Command.php(170): Symfony\Component\Console\Command\Command->run(Object(Symfony\Component\Console\Input\ArgvInput), Object(Illuminate\Console\OutputStyle))
#27 /var/www/schmuck/vendor/symfony/console/Application.php(934): Illuminate\Console\Command->run(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#28 /var/www/schmuck/vendor/symfony/console/Application.php(273): Symfony\Component\Console\Application->doRunCommand(Object(Aimeos\Shop\Command\JobsCommand), Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#29 /var/www/schmuck/vendor/symfony/console/Application.php(149): Symfony\Component\Console\Application->doRun(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#30 /var/www/schmuck/vendor/laravel/framework/src/Illuminate/Console/Application.php(90): Symfony\Component\Console\Application->run(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#31 /var/www/schmuck/vendor/laravel/framework/src/Illuminate/Foundation/Console/Kernel.php(133): Illuminate\Console\Application->run(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#32 /var/www/schmuck/artisan(37): Illuminate\Foundation\Console\Kernel->handle(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#33 {main}
Post by aimeos » 20 Oct 2019, 13:36
You have a local copy of this template where the these lines are not up to date:
https://github.com/aimeos/ai-client-htm ... #L196-L204
MikaelNazarenko
Expert
Post by MikaelNazarenko » 20 Oct 2019, 14:00
Hm, I deleted all extensions, vendor folder and executed composer install. But the same problem.. Why do I got old files ..
MikaelNazarenko
Expert
Post by MikaelNazarenko » 22 Oct 2019, 06:15
Sorry, it was stupid question, I had overwritten this template in my extension. I didn't notice it at once. Thank you for the support!
