Unable to change locale settings
flomo
Re: Unable to change locale settings
Post by flomo » 28 Oct 2019, 14:22
echo (new NumberFormatter('de', NumberFormatter::PATTERN_DECIMAL, ",##0.##"))->format(1234567890.123); // Output: 1.234.567.890,12
echo (new NumberFormatter('de_CH', NumberFormatter::PATTERN_DECIMAL, ",##0.##"))->format(1234567890.123); // Output: 1'234'567'890.12
Post by aimeos » 28 Oct 2019, 14:24
We've streamlined the behavior in dev-master so you can use "price:default" and "%1$s %2$s" for swapping price value and currency ("price:default" has precedence over "%1$s %2$s"):
https://github.com/aimeos/ai-client-htm ... 2912206a24
flomo
Post by flomo » 28 Oct 2019, 17:21
Excellent, thank you! I can't currently switch to dev-master but will try it out later.
Post by aimeos » 29 Oct 2019, 08:47
flomo wrote: 28 Oct 2019, 14:22
Can you please list again what results you need, e.g. "de_FR" -> "1'234'567'890.12", "de_CH" -> ...?
flomo
Post by flomo » 29 Oct 2019, 10:44
I need "1'234'567'890.12", no matter the locale.
But I already have a viable solution for this, by adding my own instance of view to the IOC. No need to spend more of your time for this, I already got more than excellent support for this open source project ;). Thanks again.
