Language switching in product detail issue
Kaizer
Re: Language switching in product detail issue
Post by Kaizer » 17 Mar 2020, 00:51
Adding {locale} in routes gives me a 404 error
So I just installed a fresh laravel (6.18.1) and aimeos 2019.10.19 locally with the demo data ... And still the same behavior...
I also tried both changes you mentionned to this fresh install, with no effect (route changes in config/shop.php also lead to 404)
If that helps, here is an example of the issue:
http://blackpage.be/shop/The_Jimi_Unix_ ... rrency=EUR
Here with language already switched to english -> using pretty much any link brings back to default language (fr)
Post by aimeos » 17 Mar 2020, 08:16
If you add {locale} to your routes, your URLs will be:
- http://blackpage.be/en/shop/
- http://blackpage.be/fr/shop/
Did you have two entries in the Locale tab? You need these site/locale/currency combinations:
- default/fr/EUR
- default/en/EUR
Kaizer
Post by Kaizer » 17 Mar 2020, 13:55
I don't know why I assumed the default language would not change the url...
Adding {locale} was indeed the solution
I feel stupid but very grateful for your support, thanks a lot !
