Stripe no longer working
flomo
Re: Stripe no longer working
Post by flomo » 27 Oct 2020, 08:48
I downloaded your fork as zip file and replaced all files of /vendor/omnipay/stripe, then ran "composer dump-autoload".
But still the same issue: "Call to undefined method Omnipay\Stripe\Message\Response::getPaymentIntentReference() "
flomo
Post by flomo » 13 Nov 2020, 09:35
I had to install a completely new instance of aimeos/aimeos-laravel, aimeos/ai-payments and omnipay/stripe to find the issue: the service "type" for Stripe payments has changed from "Stripe" to "Stripe_PaymentIntents".
Just changing this resolved the issue for me.
Post by aimeos » 16 Nov 2020, 13:13
Thank you, your response was very helpful!
We've added a check for the optional getPaymentIntentReference() method now so it should work with "Stripe" again when using aimeos/ai-payments:2020.10.x-dev
