Route [aimeos_home] not defined.
Re: Route [aimeos_home] not defined.
Post by aimeos » 13 Jul 2022, 11:46
Please also post your config/shop.php
peter69
Post by peter69 » 14 Jul 2022, 05:39
Hello Sir,
The problem disappeared by executing the following commands:
php artisan aimeos:clear
php artisan aimeos:setup
In case you need it, I attach configuration file (shop.php):
<?php
$routes = [];
$prefix = config( 'app.shop_multilocale' ) ? '{locale}/' : '';
if( config( 'app.shop_multishop' ) || config( 'app.shop_registration' ) ) {
	$routes = ['routes' => [
		'admin' => ['prefix' => 'admin', 'middleware' => ['web', 'auth', 'verified']],
		'jqadm' => ['prefix' => 'admin/{site}/jqadm', 'middleware' => ['web', 'auth', 'verified']],
		'jsonadm' => ['prefix' => 'admin/{site}/jsonadm', 'middleware' => ['web', 'auth', 'verified']],
		'jsonapi' => ['prefix' => 'jsonapi/{site}', 'middleware' => ['web', 'api']],
		'account' => ['prefix' => $prefix . 'profile/{site}', 'middleware' => ['web', 'auth', 'verified']],
		'default' => ['prefix' => $prefix . 'shop/{site}', 'middleware' => ['web']],
		'supplier' => ['prefix' => $prefix . 's/{site}', 'middleware' => ['web']],
		'update' => ['prefix' => '{site}'],
return $routes + [
	'apc_enabled' => false, // enable for maximum performance if APCu is available
	'apc_prefix' => 'aimeos:', // prefix for caching config and translation in APCu
	'num_formatter' => 'Locale', // locale based number formatter (alternative: "Standard")
	'pcntl_max' => 4, // maximum number of parallel command line processes when starting jobs
	'version' => env( 'APP_VERSION', 1 ), // shop CSS/JS file version
	'routes' => [
		// Docs: https://aimeos.org/docs/latest/laravel/extend/#custom-routes
		// Multi-sites: https://aimeos.org/docs/latest/laravel/customize/#multiple-shops
		'admin' => ['prefix' => 'admin', 'middleware' => ['web']],
		'jqadm' => ['prefix' => 'admin/{site}/jqadm', 'middleware' => ['web', 'auth']],
		'jsonadm' => ['prefix' => 'admin/{site}/jsonadm', 'middleware' => ['web', 'auth']],
		'jsonapi' => ['prefix' => 'jsonapi', 'middleware' => ['web', 'api']],
		'account' => ['prefix' => $prefix . 'profile', 'middleware' => ['web', 'auth']],
		'default' => ['prefix' => $prefix . 'shop', 'middleware' => ['web']],
		'supplier' => ['prefix' => $prefix . 's', 'middleware' => ['web']],
		'update' => [],
	'page' => [
		// Docs: https://aimeos.org/docs/latest/laravel/extend/#adapt-pages
		'account-index' => [ 'locale/select', 'basket/mini','catalog/tree','catalog/search','account/profile','account/review','account/subscription','account/history','account/favorite','account/watch','catalog/session' ],
		'basket-index' => [ 'locale/select', 'catalog/tree','catalog/search','basket/standard','basket/bulk','basket/related' ],
		'catalog-count' => [ 'catalog/count' ],
		'catalog-detail' => [ 'locale/select', 'basket/mini','catalog/tree','catalog/search','catalog/stage','catalog/detail','catalog/session' ],
		'catalog-home' => [ 'locale/select','basket/mini','catalog/tree','catalog/search','catalog/home', 'cms/page' ],
		'catalog-list' => [ 'locale/select','basket/mini','catalog/filter','catalog/tree','catalog/search','catalog/price','catalog/supplier','catalog/attribute','catalog/session','catalog/stage','catalog/lists' ],
		'catalog-session' => [ 'locale/select','basket/mini','catalog/tree','catalog/search','catalog/session' ],
		'catalog-stock' => [ 'catalog/stock' ],
		'catalog-suggest' => [ 'catalog/suggest' ],
		'catalog-tree' => [ 'locale/select','basket/mini','catalog/filter','catalog/tree','catalog/search','catalog/price','catalog/supplier','catalog/attribute','catalog/session','catalog/stage','catalog/lists' ],
		'checkout-confirm' => [ 'catalog/tree','catalog/search','checkout/confirm' ],
		'checkout-index' => [ 'locale/select', 'catalog/tree','catalog/search','checkout/standard' ],
		'checkout-update' => [ 'checkout/update' ],
		'supplier-detail' => [ 'locale/select','basket/mini','catalog/tree','catalog/search','supplier/detail','catalog/lists'],
		'cms' => [ 'basket/mini','catalog/tree','cms/page' ],
	'resource' => [
		'db' => [
			'adapter' => config('database.connections.' . config( 'database.default', 'mysql' ) . '.driver', 'mysql'),
			'host' => config('database.connections.' . config( 'database.default', 'mysql' ) . '.host', '127.0.0.1'),
			'port' => config('database.connections.' . config( 'database.default', 'mysql' ) . '.port', '3306'),
			'socket' => config('database.connections.' . config( 'database.default', 'mysql' ) . '.unix_socket', ''),
			'database' => config('database.connections.' . config( 'database.default', 'mysql' ) . '.database', 'forge'),
			'username' => config('database.connections.' . config( 'database.default', 'mysql' ) . '.username', 'forge'),
			'password' => config('database.connections.' . config( 'database.default', 'mysql' ) . '.password', ''),
			'stmt' => config( 'database.default', 'mysql' ) === 'mysql' ? ["SET SESSION sort_buffer_size=2097144; SET NAMES 'utf8mb4'; SET SESSION sql_mode='ANSI'"] : [],
			'limit' => 3, // maximum number of concurrent database connections
			'defaultTableOptions' => [
					'charset' => config('database.connections.' . config( 'database.default', 'mysql' ) . '.charset'),
					'collate' => config('database.connections.' . config( 'database.default', 'mysql' ) . '.collation'),
			'driverOptions' => config( 'database.connections.' . config( 'database.default', 'mysql' ) . '.options' ),
	'admin' => [
        'jqadm' => [
//            'dashboard' => [
//                'order' => [
//                    /*'subparts' => [
//                        'quick',
//                        'latest',
//                        'salesday',
//                        'salesmonth',
//                        'salesweekday',
//                        'countday',
//                        'countpaystatus',
//                        'counthour',
//                        // 'countcountry',
//                        // 'servicepayment',
//                        // 'servicedelivery',
//            'product' => [
//                    'media',
//                    'text',
//                    'price',
//                    'stock',
//                    'category',
//                    'related',
//                    'supplier',
//                    'order'
//            'supplier' => [
//                    'text',
//                    'media',
//                    'product',
//            'attribute' => [
//                'item' => [
//                    'price' => [
//                        /*'config' => [
//                            'suggest' => [
//                                'suggest 1',
//                                'suggest 2',
//                                'suggest 3',
	'client' => [
		'html' => [
			'basket' => [
				'cache' => [
					// 'enable' => false, // Disable basket content caching for development
			'common' => [
				'cache' => [
					// 'force' => true // enforce caching for logged in users
			'catalog' => [
				'lists' => [
					'basket-add' => true, // shows add to basket in list views
					// 'infinite-scroll' => true, // load more products in list view
					// 'size' => 48, // number of products per page
				'selection' => [
					'type' => [// how variant attributes are displayed
						'color' => 'radio',
						'length' => 'radio',
						'width' => 'radio',
            'checkout' => [
                'standard' => [
                    'address' => [
                        'countries' => [
                            'MX',
                    /*'billing' => [
                        'hidden' => [
                            'order.base.address.company',
                            'order.base.address.salutation',
                            'order.base.address.vatid',
                            'order.base.address.languageid',
                            'order.base.address.telefax',
                            'order.base.address.website'
	'controller' => [
		'frontend' => [
			'catalog' => [
				'levels-always' => 3 // number of category levels for mega menu
	'i18n' => [
		'en' => [
			'client' => [
				'Suppliers' => ['Brands']
        'es' => [
            'admin' => [
                'Supplier' => ['Marca'],
                'supplier' => ['Marcas'],
	'madmin' => [
		'cache' => [
			'manager' => [
				'name' => 'None', // Disable caching for development
		'log' => [
			'manager' => [
				// 'loglevel' => 7, // Enable debug logging into madmin_log table
	'mshop' => [
		'locale' => [
			'site' => 'bluexpress', // used instead of "default"
	'command' => [
	'frontend' => [
	'backend' => [
Thank you very much for your help,
Regards
