Route problem in multisite
Re: Route problem in multisite
This was only an example. You have to use the airoute() function where you generate the URL that cases the error.
- VirtualSpy
- Advanced
Why are you not accepting it is bug from your side because i didn't change any template except thisVirtualSpy wrote: ↑27 Oct 2022, 14:00already airoute() function is here in this templateaimeos wrote: ↑27 Oct 2022, 13:52 Read:
The root cause for the error is that the links to the auth routes are not generated by the airoute() function in your templates like here:
https://github.com/aimeos/aimeos/blob/m ... ade.php#L9
<x-guest-layout> <x-auth-card> <!-- Validation Errors --> <x-auth-validation-errors class="mb-4" :errors="$errors" /> <form method="POST" action="{{ airoute('register') }}"> @csrf <!-- Name --> <div> <x-label for="name" :value="__('Name')" /> <x-input id="name" class="block mt-1 w-full" type="text" name="name" :value="old('name')" required autofocus /> </div> <!-- Email Address --> <div class="mt-4"> <x-label for="email" :value="__('Email')" /> <x-input id="email" class="block mt-1 w-full" type="email" name="email" :value="old('email')" required /> </div> <!-- Password --> <div class="mt-4"> <x-label for="password" :value="__('Password')" /> <x-input id="password" class="block mt-1 w-full" type="password" name="password" required autocomplete="new-password" /> </div> <!-- Confirm Password --> <div class="mt-4"> <x-label for="password_confirmation" :value="__('Confirm Password')" /> <x-input id="password_confirmation" class="block mt-1 w-full" type="password" name="password_confirmation" required /> </div> <div class="flex items-center justify-end mt-4"> <a class="underline text-sm text-gray-600 hover:text-gray-900" href="{{ airoute('login') }}"> {{ __('Already registered?') }} </a> <x-button class="ml-4"> {{ __('Register') }} </x-button> </div> </form> </x-auth-card> </x-guest-layout>
<div class="form-group row">
<div class="col-md-12 text-left">
@if (Route::has('register'))
<a class="underline text-sm text-gray-600 hover:text-gray-900" href="{{ airoute('register') }}">
{{ __('Create Account') }}
</a>
@endif
Don't know where the error exactly is located. E-mail verification is something Laravel does internally and without much access from outside.
You could try to replace this in your routes/web.php:
You could also modify this file:
https://github.com/aimeos/aimeos/blob/m ... s/auth.php
Add the settings in $conf there but not for these routes:
https://github.com/aimeos/aimeos/blob/m ... hp#L38-L47
Whatever works best. If you find a good solution, please create a PR so it will be fixed for all.
Route::group($conf ?? [], function () {
require __DIR__ . '/auth.php';
//replace with
- VirtualSpy
- Advanced
i seprated this routesaimeos wrote: ↑28 Oct 2022, 07:02 Don't know where the error exactly is located. E-mail verification is something Laravel does internally and without much access from outside.
You could try to replace this in your routes/web.php:You could also modify this file:Code: Select all
Route::group($conf ?? [], function () { require __DIR__ . '/auth.php'; }); //replace with require __DIR__ . '/auth.php';
Route::get('verify-email/{id}/{hash}', [VerifyEmailController::class, '__invoke'])
->middleware(['signed', 'throttle:6,1'])
->name('verification.verify');
Route::get('confirm-password', [ConfirmablePasswordController::class, 'show'])
->name('password.confirm');
Route::post('confirm-password', [ConfirmablePasswordController::class, 'store']);
Route::get('reset-password/{token}', [NewPasswordController::class, 'create'])
->name('password.reset');
Item with ID "22" in "customer.id" not found
This is usually the case if the user has been created for a different site and is bound to that site ID now instead of the current site (see users.siteid column for that user). You can set the site ID of the user to an empty string to make that account available for all sites.
- VirtualSpy
- Advanced
please tell me how can i set site ID empty while user registration.aimeos wrote: ↑13 Dec 2022, 10:09 This is usually the case if the user has been created for a different site and is bound to that site ID now instead of the current site (see users.siteid column for that user). You can set the site ID of the user to an empty string to make that account available for all sites.
- VirtualSpy
- Advanced
Thank you so much for your support from site id as an empty string now user can login on all sitesVirtualSpy wrote: ↑13 Dec 2022, 10:20please tell me how can i set site ID empty while user registration.aimeos wrote: ↑13 Dec 2022, 10:09 This is usually the case if the user has been created for a different site and is bound to that site ID now instead of the current site (see users.siteid column for that user). You can set the site ID of the user to an empty string to make that account available for all sites.
