creating managers
Re: creating managers
Run this command to create/update/migrate the table structure and data:
php artisan aimeos:setupProfessional support and custom implementation are available at Aimeos.com
Thank you, knowing of the command made me check closer what I did wrong.
I got confused by the namespace Aimeos\Upscheme\Task and had placed my task inside the directory 'src\Aimeos\Upscheme\Task' instead of 'setup\default'.
- mahammadareef
public function search( \Aimeos\Base\Criteria\Iface $search, array $ref = [], int &$total = null ) : \Aimeos\Map
$context = $this->context();
$conn = $context->db( $this->getResourceName() );
$items = [];
$required = ['contact'];
$level = \Aimeos\MShop\Locale\Manager\Base::SITE_SUBTREE;
$level = $context->config()->get( 'mshop/contact/manager/sitemode', $level );
$cfgPathSearch = 'mshop/contact/manager/search';
$cfgPathCount = 'mshop/contact/manager/count';
$results = $this->searchItemsBase( $conn, $search, $cfgPathSearch, $cfgPathCount,
$required, $total, $level );
// dd($results);
try
while( ( $row = $results->fetch() ) !== null ) {
[quote]$items[$row['contact.id']] = $this->applyFilter( $this->createItemBase( $row ) );[/quote]
catch( \Exception $e )
$results->finish();
throw $e;
// dd(map( $items ));
return map( $items );
this is my search code contact/manager/standard class , where iam getting
inUndefined array key "contact.id"
#0 D:\laragon\www\laravel-project\vendor\laravel\framework\src\Illuminate\Foundation\Bootstrap\HandleExceptions.php(259): Illuminate\Foundation\Bootstrap\HandleExceptions->handleError(2, 'Undefined array...', 'D:\\laragon\\www\\...', 267)
line ....$items[$row['contact.id']] = $this->applyFilter( $this->createItemBase( $row ) );
please help me solve this
The column is only named "contact.id" if you use this as alias in your SQL statement in the manager configuration, e.g.:
SELECT "id" AS "contact.id", ...
karoleq991
Re: creating manager and admin panel
I'm having trouble creating a template.aimeos wrote: 14 Nov 2022, 17:27 Create an Aimeos migration first in the ./setup/default/schema/contact.php directory of your extension so your table will be automatically created and updated like this one:
https://github.com/aimeos/aimeos-core/b ... review.php
The corresponding setup task should be like this one in the ./setup/Contact.php directory of your extension:
https://github.com/aimeos/aimeos-core/b ... Review.php
Documentation for migrations and setup tasks is available here:
https://aimeos.org/docs/latest/infrastr ... igrations/
Next, create a manager and item for your new data domain in ./src/MShop/Contact/Manager/Standard.php, ./src/Contact/Item/Standard.php and ./src/MShop/Contact/Exception.php like this one:
https://github.com/aimeos/aimeos-core/t ... hop/Review
You can copy, paste and adapt the files. The corresponding config must be in ./config/mshop/contact.php and should look like this one:
Finally, create the class file for the admin backend in ./src/Admin/JQAdm/Contact/Standard.php like this one in your extension:
https://github.com/aimeos/ai-admin-jqad ... andard.php
Create the corresponding templates like here:
https://github.com/aimeos/ai-admin-jqad ... adm/review
Configure the permissions and navbar entry of your new admin backend panel like here in the ./config/admin/jqadm/ directory of your extension:
https://github.com/aimeos/ai-admin-jqad ... dmin/jqadm
After doing it, a white page is displayed and the template does not load, even though I have placed the list.php and item.php files in the templates/admin/jqadm/<my panel name> directory of my extension. Please help me
This is most likely due to a PHP or VueJS error. Remove everything from your templates and add parts one by one to see where the error occurs.
