Updating cart address at login
Re: Updating cart address at login
Post by aimeos » 01 Dec 2015, 17:57
swpierce wrote: After successful login, I update the address in the cart if needed. I then grab the delivery service item and get the correct shipping. Works great. Post-login redirects to the basket view. Basket shows updated shipping but mini-basket still shows values from prior to logging in.
Well, the mini basket is cleared automatically by the basket standard component if something changes by using this method:
https://github.com/aimeos/aimeos-core/b ... ct.php#L27
The problem is that you do and can not use it because you are changing the basket directly. Thus, you need to clear the session manually.
As an alternative, you can disable caching for the small basket by using this config key:
https://github.com/aimeos/aimeos-core/b ... ct.php#L71
